Old 10-15-2016, 01:45 AM   #1
20pack10 hot water only for a few seconds
Hey guy so I have a new 20pack10 toy hauler and I absolutely love it !
I am plugged in to power, and also have propane open for furnace.
I am only getting hot water for a few seconds? And then it's cold... if I turn hot water switch on I don't see any thing happen but with electric I don't know if I will
I checked fuses and all , breakers etc, and all ok....
I also bleed water off at the valve under the out door cover , it has water, also the electric switch is on
If a brand new unit, my first use??? Any thing that causes that?
Ozziedodge67 is offline   Reply With Quote
Old 10-15-2016, 04:50 AM   #2
wmtire's Avatar
When you open the Temp & Pressure relief valve (T&P) on the water heater, is the water that comes out there hot? If so, then most likely you have the bypass/crossover valve (s) set incorrect. This is a common thing that dealers fail to explain.
See if these links below can help:
http://www.forestriverforums.com/for...st-103381.html
and if applicable:
http://www.forestriverforums.com/for...tml#post327988
2011 Flagstaff 831 RLBSS
Old 10-15-2016, 08:29 PM   #3
and if applicable:
100% correct. The cold water was closed, the middle open.....
Although when I check the pressure release valve I had water.
••although I do not have hot water exactly like I should. No issue... fixed....
Should I worry about my element now???? :/
Can't believe I was not told about that
Old 10-15-2016, 08:37 PM   #4
If it's keeping the water hot on electric only, you're good. The element either works or it doesn't.
2011 Traverse LT, 3.6L, FWD
Old 10-15-2016, 08:39 PM   #5
wmtire's Avatar
Uhhhh, you may have missed these posts in your other thread, but understand you were stressed to the max at that time too:
http://www.forestriverforums.com/for...ml#post1335923
http://www.forestriverforums.com/for...ml#post1335964
Old 10-15-2016, 08:39 PM   #6
Yes... if the switch outside inside the door is turned to electric it's running on electric correct??? When I listen I can hear the flame heating
Old 10-15-2016, 08:46 PM   #7
Shouldn't be any flame with electric.
Open the outside door and turn on the switch there (turns on electric heating element. Go inside your TT and turn OFF the switch there (turns off the gas).
Then if it keeps making hot water, you'll know your electric heating element is still good.
You can run both together if desired - it will recover quicker if, say, two people want to take showers close together.
But most people just run it on electric if they have shore power - why waste your gas?
Old 10-15-2016, 09:01 PM   #8
So it will only work when I turn my propane on... the outside switch is on..
If I open the propane bottles and then turn the hot water switch on inside the camper I have hot water
So I guess the electric element burned up because I tried a good bit with the hose on the cold side off at the water heater
16' Cherokee wolf pack 20pack10
Rzr 1000
Outlander 1000
•All pulled by 15' Gmc 2500HD duramax
Old 10-15-2016, 10:18 PM   #9
One other thing to check - look for the circuit breaker for the water heater. You might have gotten lucky and it tripped; but chances are slim.
Old 10-16-2016, 09:00 PM   #10
Check breaker and it is on, so I assume the element is nice and toasty...
My buddy knows how to do it( owns a few RV's)
My question is I have looked for a serial number and don't see it... it's a suburban unit
It's in a 2015 20pack10 wolf pack...
Rzr 1000
Outlander 1000
Old 10-16-2016, 09:25 PM   #11
There should be a model number somewhere on it. I've attached the owner's manual that covers the most popular models.
Old 10-17-2016, 01:57 PM   #12
SW6DE is the unit...
I bought a new element $35 not bad
Does the water heater switch have to be on as well as the outside electric switch???
Rzr 1000
Outlander 1000
Old 10-17-2016, 02:30 PM   #13
Any one???
Rzr 1000
Outlander 1000
Old 10-17-2016, 03:57 PM   #14
wmtire's Avatar
Any one???
Ozzie, it's all explained in the link I provided in post #2 about the electric switch.
Old 10-17-2016, 04:09 PM   #15
KyDan's Avatar
We have info in the FAQ area about water heaters!
Read it!!
You can get a 120v 1500 watt screw in heater at Home Depot for under $10.
Here's one for $7
1500-Watt 120-Volt Screw-In Type High Watt Density Water Heater Element-15896 - The Home Depot
Two important things to remember when shopping for a HW heater at Home Depot, hardware store, Lowes etc... You most likely need a 120 Volt and 1400 or 1500 watt.
(Large 50 amp service seasonal trailers might use a 240 volt so you have to check!)
Peace!
Dan & Rita D
Old 10-17-2016, 06:38 PM   #16
I have read it.
If I have electric switch outside on do I need the water heater switch on? Or only if I want to use both
Rzr 1000
Outlander 1000
Old 10-17-2016, 09:37 PM   #17
RJJ
Outside switch runs electric element. Inside switch runs propane to heat water. Use one at a time or both. Each switch controls a different source to create hot water.
2015 Georgetown 329DS
2014 Chevy Equinox
RJJ is offline   Reply With Quote
Old 10-18-2016, 07:08 AM   #18
KyDan's Avatar
My last 3 trailers had the outside "hidden" switch for the electric heater.
Since I hated going out there to switch it I turned it off and on with the
circuit breaker inside. The outside switch eventually stuck on in my last
trailer. I didn't care because I used the breaker.
My current rig has 2 inside wall switches- one for LP gas hot water and one
for electric hot water.
This is why I hesitated to give you a definitive answer. I didn't figure it would be helpful to tell you "maybe" to your question!
Happy camping!
Peace!
Dan & Rita D
Old 10-18-2016, 10:20 AM   #19
If you only have the outside switch for the electric heating element and you either get tired of going outside to use it and you don't want to use the circuit breaker, you can install an inside switch like I did. See pics and wiring diagram. Note in the first pic I replaced the electrical box that the water heater plugs into because you need to install a "real" duplex outlet instead of that crappy RV style they use.
ID:	123324   Click image for larger version
ID:	123325   Click image for larger version
ID:	123326   Click image for larger version
hot water, water
