Old 09-20-2016, 09:17 PM   #1
Question 23FB13 2017 wall board loose/ripples inside at the front curve..
On the second trip with our new RV my wife and I noticed ripples on wall on the inside at the front, where the curve is, the wall board seems to have come loose? Not sure if this is normal because of the curve or if it should be tight and smooth against the wall. Like window tint on a curved window it would have to be sliced, cut and overlapped. This was not and is just one piece of wallpaper/wall board. There are no water marks or evidence of water damage. Only when you stand off to to the side or run your hand along the wall is it obvious. I this a mfg defect? Insufficient glue?
DDPope13 is offline   Reply With Quote
23fb
