Just picked up a new XLR fiver last weekend. Has the second AC already in the bedroom. Since it was ordered from the factory that way it has it's own mounted wall switch. I don't think they put the switch in if it's not a factory install, so the controls will be on the AC unit itself. As long as you are plugged into 50 amps, you can run both AC's at the same time, high/low doesn't matter. One note though, I was really shocked at how loud the bedroom AC is. Sounds like a jet in there, and it didn't get much quieter when the compressor cycled off. Wife is a very light sleeper, so I can't wait to test this out on an actual camping weekend.
