Old 08-09-2009, 04:54 AM   #1
32qbbs 2008
Can anyone advise how to get access to rear of shower taps without dismantling shower?there is no panel on wall in dinette area as was suggested.
It seems a design fault if there is no other access.
Regards,Paul.
Chrissy and Paul is offline   Reply With Quote
Old 08-09-2009, 10:29 AM   #2
NWJeeper's Avatar
On our Georgetown they actually put an access port right into the shower surround. It's about 5" in diameter and is a screw in disk that can be removed to gain access to the plumbing behind the shower controls. If you don't have something like this it wouldn't be hard to add yourself. I am sure these access ports can be bought at an RV parts supplier, then just cut a hole through the shower surround right under the shower fawcet and install the access port.
Ed & Wendy
www.nwjeepn.com
Old 08-09-2009, 03:43 PM   #3
Campfire Master
On my Wildcat there is an access door on the outside. It is locked with the famous 751 key and is quite high up on the rig. Take a walk around the backside of yours and look up.
AVid
AVid is offline   Reply With Quote
32qbbs
