Old 05-01-2019, 10:00 PM   #1
3500 lb Lippert axle nut socket size
Anyone know what socket size to use on a 3500 lb Lippert axle for the axle castle nut?
billybigrigger is online now   Reply With Quote
Old 05-01-2019, 10:40 PM   #2
Never used anything but slip joint pliers.
https://www.amazon.com/Channellock-4.../dp/B00002N5JF
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 05-01-2019, 11:16 PM   #3
Retired Old Fart
dward51's Avatar
Slip joint pliers or crescent wrench for me also. It's LCI part number 122081 if you bugger it up, or look for a 1"x14tpi hex castle nut.
But based on the nut being 1"x14, the socket should be a 1 1/2".
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 05-02-2019, 06:42 AM   #4
SilhouettePenny's Avatar
Slip joint pliers are all you need, not a lot of torque required. What are you trying to do sir? I'm asking because I've seen guys try to remove this castle nut with the cotter pin still inserted. They got it off but what a mess.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 05-02-2019, 07:25 AM   #5
Cotter pin will be removed! LOL! I am getting ready to do a bearing repack by hand. I am over paranoid about torque values and would like to tighten to the 50 lb-ft spec using a torque wrench.
Old 05-02-2019, 07:53 AM   #6
Iwannacamp's Avatar
Some axle manufacturers say to torque to 50 FT lbs and then back off without turning wheel to set the bearing torque. The same instructions said use a 12" wrench or ratchet with moderate human pressure and that was approximately 50#.... I think I would stay with the "old school" way or use a torque wrench as most people won't know what 50# feels like.
2017 Puma 297RLSS
Old 05-02-2019, 07:55 AM   #7
Iwannacamp's Avatar
Lol... just what I posted. Get you a wrench and do it the right way. You da man!
2017 Puma 297RLSS
Old 05-02-2019, 06:49 PM   #8
Also while on subject, what size cotter pin are you all using? 1/8 X 1-3/4?
Old 05-02-2019, 07:00 PM   #9
Just donít forget to do the second part...back the bug off and just make finger tight.
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
Jfkmk is offline   Reply With Quote
Old 05-03-2019, 12:25 AM   #10
Retired Old Fart
dward51's Avatar
Official LCI part number is 122075, but yes, it's a 1 3/4" x 1/8" cotter pin. Much cheaper at hardware store than what Lippert sells them for ($3 each). I usually buy them in a 10 pack.
Old 05-03-2019, 08:55 AM   #11
The 50 ft-lbs of torque is to ensure the bearings are properly re-seated, especially if you've replaced the bearings. A torque wrench and/or socket isn't mandatory but may help some folks. The castle nuts end up being finger-tightened and then backed off to the align the cotter pin to the nearest hole on the axle shaft. Dexter instructions are here: https://www.dexteraxle.com/docs/defa....pdf?sfvrsn=10
If you need a socket or wrench to undo these nuts someone has been in there before you and re-installed the castle nuts wrong and may have even damaged bearings.
We once had our dealer remove our drums and do a bearing inspection & repack. Several thousand miles later on a long road trip, I found that one of the drums/hubs was quite a bit hotter than the rest using an IR gun. Got home, pulled the wheels off and found I had to use a socket to undo the nuts. They were well over-tightened. I ended up replacing the bearings with Timkens. Because of this (and plenty of other things) I no longer trust a dealer for doing anything...
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 05-03-2019, 09:01 AM   #12
jeff64's Avatar
X2
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-03-2019, 09:16 AM   #13
As mentioned, I believe the 'official' size is 1/8" x 1-3/4" for the cotter pin.
But really, anything close will do. It just keeps the nut from backing off.
I've even used a nail in a pinch.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 05-03-2019, 09:24 AM   #14
I've always wondered about cotter pin quality. It's not like they have grade marking on them or are color coded.
Curious - can a pack of them from HF be just as good as some from an auto parts store or industrial supplier? I'm restoring a couple of cars and not sure if it matters much?
And what if you need metric cotter pins?
Langley, BC
Old 05-03-2019, 04:52 PM   #15
Retired Old Fart
dward51's Avatar
Probably all from the same factory in China anyway.
If you need a left handed metric cotter pin, they are the hardest ones to find!!!! Usually have to come from the UK, as they use them on trailers over there (made to work best when driving on the left side of the road).
Old 05-04-2019, 06:51 AM   #16
I always like to pick up cotter pins from Fastenal! I think they have most every size imaginable!
3500, 500, axle
