Old 11-21-2014, 04:03 PM   #1
4KY Generator
Why does gasoline not come into the Generator from Coach tank? tank on coach is full!
bill2004lex is offline   Reply With Quote
Old 11-21-2014, 07:15 PM   #2
Average Joe
MrJoe's Avatar
Bad fuel pump?
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 11-21-2014, 07:35 PM   #3
Has new Fuel pump! I removed the hose coming from the RV tank, no gas coming out!
Old 11-21-2014, 07:41 PM   #4
Average Joe
MrJoe's Avatar
Has it ever worked?
May not be politically correct, but can you try siphoning it through the hose? See any kinks?
Joe and Karen
Old 11-21-2014, 08:10 PM   #5
mud yapster's Avatar
Fuel line may be kinked off. Fuel filter stopped up. Bad fuel pump.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-21-2014, 08:17 PM   #6
mcnabbwr's Avatar
Is there a separate shut off valve between the tank and generator?
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 11-22-2014, 12:20 AM   #7
Not on mine
Old 11-22-2014, 12:23 AM   #8
CAT-RN's Avatar
Try blowing air backwards thru the line?
Russell
CAT-RN is offline   Reply With Quote
Old 11-22-2014, 12:26 AM   #9
Check the fuel line brackets that the fuel line runs thru going back to the tank, mine were smashing off the fuel line.
Old 11-23-2014, 09:59 AM   #10
2014 XLR 27HFS
dave961's Avatar
If it never worked, I would guess the line is kinked. The factory guys love pulling zip ties really tight without looking at what is getting kinked. My black tank flush (water) line was bent 180 degrees and tie wrapped in place tight.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 12-04-2014, 08:31 PM   #11
It worked this summer, then it stopped! I think the fuel line from the gas tank on RV might have collisped! Have to check it later when I can get it on a lift! thanks everyone!
generator
