Old 02-29-2016, 03:40 PM   #1
JohnF's Avatar
50 Amp Home Wiring
I have this switch I would like to mount next to the 50amp outlet for my RV. I know I can turn power on and off to the outlet with the breaker in the building but would like the convience of controlling the power near the outlet.
Is this the proper box for the job? I am running 6/3 w/grd through this switch. Do I just tie the neutral wires together inside the box and terminate the neutral at the outlet? The same with the ground? As you see this box only controls the two hot wires going to the outlet.
John
ID:	100764   Click image for larger version
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is online now   Reply With Quote
Old 02-29-2016, 03:48 PM   #2
wmtire's Avatar
Originally Posted by JohnF View Post
I am running 16/3 w/grd through this switch.
John, is this a typo, perhaps?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-29-2016, 03:48 PM   #3
caper's Avatar
Your 16/3 wire is undersized for a 50 amp service.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-29-2016, 03:52 PM   #4
JohnF's Avatar
Sorry, typo. I corrected it.
Ohio
2015 Ford F-350
4WD SRW Diesel
Old 02-29-2016, 04:13 PM   #5
Mr. Dan's Avatar
Ha! I was about to type FIRE!
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 02-29-2016, 04:19 PM   #6
The disconnect will work fine you want to splice the neutral and bond the ground to the box.
2016 Coachmen Apex 288BHS
2015 F150 Sport 4x4 3.5 Eco Boost
4B11T is offline   Reply With Quote
Old 02-29-2016, 05:56 PM   #7
X2 way undersized for 50 amp
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 02-29-2016, 06:19 PM   #8
Mr. Dan's Avatar
OP corrected his typo to 6/3. See correction in initial post.
Sent (I think)
Old 02-29-2016, 06:27 PM   #9
Yep my bad.
Old 02-29-2016, 06:33 PM   #10
JohnF's Avatar
Thanks! Back to work on it again tomorrow.
Ohio
2015 Ford F-350
4WD SRW Diesel
50 amp, wiring
