Old 06-16-2011, 06:39 AM   #11
This discussion begs another question. How much voltage drop is acceptable to run my 15K AC safely? I am running my shore power (20A breaker) through the original cord and a heavy 50ft RV extension cord. This works fine for most things, but I would like to run the AC when loading the trailer. I could run the fridge on propane. I know the startup amperage is the issue. Yes, I tried it an it does run the AC. The electronic thermostat always runs the fan first, and then starts the compressor after a delay. I just want to ensure I don`t damage the AC unit. I would buy and adapter and run only the extension cord, 50 ft vs 80ft length. The voltage drop would be cut almost in half.
James and Karen
Warner Robins, GA
2011 Lacrosse 301RLS
2007 Tundra CM 5.7
Reese Dual Cam
jjarrard is offline   Reply With Quote
Old 06-16-2011, 06:48 AM   #12
grhodes50's Avatar
Originally Posted by gucci View Post
My TT has a 30 amp cord but I could get an adapter to covert to a 50 amp...
I maybe reading your post wrong, but....
You will not convert to 50 amps by using an adapter. The adapter reduces the 50 amp to 30 amp. I believe two of the 50 amp prongs are wired with 110v. The adapter basically disconnects one of those prongs converting the 50 amps to 30 amps and that is what allows you to plug your 30 amp tt into a 50 amp plug in.
So whether you plug into a 30 amp plug or a 50 amp with an adapter, you're still just using 30 amps.
Gary & Trish
2018 Nights Camped - 5
Old 06-16-2011, 07:12 AM   #13
Herk7769's Avatar
Originally Posted by grhodes50 View Post
The adapter reduces the 50 amp to 30 amp. I believe two of the 50 amp prongs are wired with 110v. The adapter basically disconnects one of those prongs converting the 50 amps to 30 amps and that is what allows you to plug your 30 amp tt into a 50 amp plug in. So whether you plug into a 30 amp plug or a 50 amp with an adapter, you're still just using 30 amps.
Well. not really. The 50 amp plug has two 110 "legs" (one runs the primary AC side of your power center and the other runs the secondary side of your power center); a neutral and a gound. The 30 amp plug has a single 110 leg that runs all AC in your camper, a neutral and a ground.
The "adapter" just uses a 50 amp plug (so you can plug into that outlet) and connects the "primary leg" to the socket pin of a 30 amp socket on the other end. Neutral and ground are also connected.
With an adapter you CAN NOT pull more than 30 amps through the cord because the camper's main will trip if you try.
Name:	20-50amp Service Panel.jpg
HAM CALLSIGN - KC3FFW
Old 06-16-2011, 07:18 AM   #14
Herk7769's Avatar
Originally Posted by jjarrard View Post
This discussion begs another question. How much voltage drop is acceptable to run my 15K AC safely? I am running my shore power (20A breaker) through the original cord and a heavy 50ft RV extension cord. This works fine for most things, but I would like to run the AC when loading the trailer. I could run the fridge on propane. I know the start up amperage is the issue. Yes, I tried it an it does run the AC. The electronic thermostat always runs the fan first, and then starts the compressor after a delay. I just want to ensure I don`t damage the AC unit. I would buy and adapter and run only the extension cord, 50 ft vs 80ft length. The voltage drop would be cut almost in half.
I also use a long 30 amp extension cord to power my camper at many places I camp. I bought a Franks autotransformer Voltage Booster to increase the voltage at the camper to make up for any losses in the extension cord or even at the campground pedestal (large campgrounds in hot weather at the end of a row) when the voltage drops to below 110 VAC. The attached files show how the voltage is boosted based on incoming voltage. Be aware that AMPS available is reduced when the voltage is being boosted. (the booster "uses amps to make volts" - not really but you get the idea).
Name:	Franks Voltage Booster Page 1.jpg
ID:	6379   Click image for larger version
Name:	Franks Voltage Booster Page 2.jpg
ID:	6380   Click image for larger version
Name:	Franks Voltage Booster Page 3.jpg
ID:	6381   Click image for larger version
Name:	Franks Voltage Booster Page 4.jpg
Old 06-16-2011, 07:38 AM   #15
jimh's Avatar
one consideration abt adapting to a 50 amp service: ur wire size is for 30 amp. ur 30 amp main in the trailer should protect u but properly, the line between the source and ur trailer will not be properly protected.
with that said, i wouldn't have any problem adapting to 50. i encountered one park that offered either 20 amp or 50. the park had an adapter to go from the 50 to 30.
on ur wire size. if u run a #12 extension cord, i wouldn't be concerned abt the length being 50 ft. i doubt very seriously if ur going to drop the voltage enough to damage anything.
i would have to look it up but i believe ur air conditioner will run down to 100 volts. the tag on the unit is the best reference for that. i wouldn't push it though. measure the voltage in ur camper with the unit on, if it has dropped to 110, i would be concerned.
my old camper, i ran a 100' extension cord from the house and had no issues running the air, refrigerator, and converter (lights). no issues. couldn't go beyond that though.
u still want to keep ur runs as short as possible. i wouldn't use an extension rated under 20 amps at all.
jimh is offline   Reply With Quote
Old 06-16-2011, 08:09 AM   #16
I need all available amperage for compressor startup. I realize I may have to run a 30 amp service to the trailer eventually or buy a generator. Since I can run the AC on the 20 amp breaker, excessive voltage drop damaging the compressor is my concern. I believe the extension cord is 10 gauge. It is 50 ft long and I would have to use a generator adapter that is about 1 ft long. Assuming a 20 amp load I have the voltage drop calculated at 2.5 volts or 117.5 volts available. With the OEM cord added it goes to 3.9 and 116.1 volts. The question is wether 117.5 volts will safely operate the 15K BTU AC and 12 volt converter?
James and Karen
Warner Robins, GA
2007 Tundra CM 5.7
Reese Dual Cam
Old 06-16-2011, 09:46 AM   #17
GENERALLY, if your camper is 30 feet(ish) or less, one or two axles, with only one AC on top, it is a 30 amp service. 3 axles or more, 2 AC's, motorhome(most), then chances are good your'e a 50 amp. BESIDES that, the plug- ins are 4 prongs for 50 and 3 prongs for 30, so they won't fit anyway. Even with a plug adapter and you're 30 amp into a 50 amp plug in, you would only get 30 amps to the trailer, because there are only 3 wires going into your camper anyway. Randy
Old 06-16-2011, 10:17 AM   #18
grhodes50's Avatar
Thanks Lou. That's what I was trying to point out. The way the OP had worded his post it sounded as if he thought the adapter would "change" his 30 amp tt to a 50 amp tt.
Gary & Trish
50 amp
