Old 04-15-2011, 09:24 AM   #1
A/c question
Hello everyone i am new to the RV world and have learned alot so far.
Here is what i'm working with, i have a 2006 392 Salem TT.
The question i have is its a big trailer and it only has one A/C unit on it. It does ok at night when the sun goes down but during the day it struggles. Does anyone know if you can add a second unit? Any input would be great.
Thanks,
Kevin Allison is offline   Reply With Quote
Old 04-15-2011, 09:33 AM   #2
sherdep's Avatar
to add another A/C unit you would need to cut a hole in your roof and find a place to get electric to it - if you have a 30 amp service on the side of your camper you would most likely have to upgrade to 50 amp service cause the two A/C units would draw almost 25 to 30 amps without anything else running.
Does it feel like it is blowing cold or is it warm when the sun is out - could be low on Freon and freezing up
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-15-2011, 09:38 AM   #3
Herk7769's Avatar
As a 2006 it is almost 6 seasons old so it sounds like it needs service or replacement to me as well.
Maybe now is the time to upgrade (replace it) with a 15K unit. You would not need upgraded electrical service and it will eliminate the need for a second unit completely.
HAM CALLSIGN - KC3FFW
Old 04-15-2011, 09:45 AM   #4
sherdep's Avatar
I like your idea Lou about replacing it with a 15K unit instead of cutting a hole in the roof which could possibly bring another place for a leak.
I know the 13K draws around 13 to 15 amps - how much more does a 15K draw?
Old 04-15-2011, 09:51 AM   #5
It has 50 amps running to the pole but not sure if the trailer has been upgraded.
It blows cold all the time. It does trip the breaker if you turn it down to low when it's hott outside. I may have breaker problems.
Old 04-15-2011, 09:52 AM   #6
What do you think it has from the factory?
Old 04-15-2011, 10:02 AM   #7
Herk7769's Avatar
Unless it was upgraded at time of purchase, the standard one is 13K BTU.
Old 04-15-2011, 10:04 AM   #8
Ok thanks. Do they make one bigger than the 15k and if so can a 30amp handle it.
I have a motto that i go by alot and that is "go big or go home".
Old 04-15-2011, 10:06 AM   #9
Herk7769's Avatar
http://www.coastdistribution.com/PDF...uct%20Page.pdf
about 16 amps including compressor load.
Old 04-15-2011, 10:14 PM   #10
Nothing bigger than a 15,000 btu unit; but it should fit the exact spot just the same as the 13,500 unit. Not a lot bigger, but a new unit should be a bit more efficient. Wiring should be an exact swap, also. Randy
