Old 03-10-2018, 05:06 PM   #1
Occasional opinionator
RT Kramer's Avatar
A/C roof gasket regular tightening schedule?
Hi all, I'm just wondering how often and how much do you regularly check and/or tighten down you A/C mounting bolts to make sure it's roof seal gasket doesn't leak and cause water damage to the roof? Obviously the seal loosens up from age and movement while towing etc., and it will eventually begin to leak. I once was told by a StarCraft dealer to tighten them several turns every year and to replace the seal every five years. What do you all do?
R/T
The Finger Lakes Area, NY
'16 Rockwood Signature Ultra Lite 8311WS
'03 Ford Excursion 7.3 diesel
RT Kramer is offline   Reply With Quote
Old 03-10-2018, 05:38 PM   #2
Witch Doctor's Avatar
To be honest I have never in 5 years, do I check it yes. If you keep tightening it I think will depress, you will see it leaking on the inside if it's .
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-10-2018, 06:11 PM   #3
NMWildcat's Avatar
I check mine while doing spring cleaning roof checks. They have never been loose yet.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
gas, roo, roof
