Old 01-08-2016, 10:38 AM   #1
A C unit. For Heat
Is there any kind of unit up grade or replacement to use AC for heater in stead of using propane thanks
retired on a mountain is offline   Reply With Quote
Old 01-08-2016, 10:51 AM   #2
Kels4g's Avatar
Our ac says it has heat as an option. It doesn't work though so I'm wondering if it's broken or we just don't have that option in our trailer.
Kelly and Stephen with Daisy, Lily, and Roxy!
Run Free Sweet Riley 2009-2015
Visit our blog for more information and details!
www.kels4g.com
Kels4g is offline   Reply With Quote
Old 01-08-2016, 09:56 PM   #3
I believe you can add heat strips inside it. But we just use a small electric ceramic heater. I put it on the floor in the kitchen and a small fan to move the air around. Works great and cheap.
AGFazio is offline   Reply With Quote
Old 01-08-2016, 10:06 PM   #4
Bluepill's Avatar
Heat rises. The portable heaters on the floor work best.
I love having one to preheat the shower stall on a cold morning. Yes, I am a sissy.
2008 Itasca Meridian 37H
Old 01-09-2016, 12:15 AM   #5
Oklahoma Proud
MillerTime's Avatar
There are heat pump replacement units available, and they will work to heat until its about 37-38į outside and also cool in the summer. (In the south a lot of homes are equipped with heat pumps with axillary electric or gas furnaces for when it dips cooler)
Also, as mentioned above, some units you can add heat strips.
Old 01-09-2016, 01:51 AM   #6
I also use a portable heater. Actually , I use a Heat Surge hybrid mini fireplace. It's vey efficient , safe, no stinky element type heat and the heat is soft and confortable. They are a bit pricey but totally worth it! It's also fun to have a mini fireplace
Auntielo1 is offline   Reply With Quote
Old 01-09-2016, 01:53 AM   #7
HAHAHAHA that's not sissy. It's smart! Rv'ing is more like glamping than camping
Old 01-09-2016, 04:23 AM   #8
Witch Doctor's Avatar
If it's a Colman they have a heat strip kit to install but you need to have an extra wire to run it. Mine has only 5 wires so I would have to pull a wire for it. The other option as mentioned is to replace the A/C with a heat pump as Miller Time pointed out. I just use the heater in the fireplace and a 1500 watt ceramic, with both on they will cook you out. If the A/C go's down then that would be a good time for a replacement to switch to a HP.
Coachmen M/H
Concord
2018 / 300 DSC
Old 01-09-2016, 11:44 AM   #9
milvet33's Avatar
Heat
Auntielo1 X2 Heat Surge is great!
milvet33 is offline   Reply With Quote
Old 01-09-2016, 01:05 PM   #10
lckeehne's Avatar
I have an AC with heat strip. Works good.
I also use an electric heater in rest of coach song stay off propane. To reduce costs.
lckeehne is offline   Reply With Quote
