Old 02-17-2016, 07:28 PM   #11
Since the unit is probably out of warranty, if it is an electronic issue like a $25 capacitor versus a compressor or freon issue, fixing it is probably less costly then replacing.
Rich5117 is offline   Reply With Quote
Old 02-17-2016, 07:44 PM   #12
Too Tall's Avatar
Put the fan on either hi or low but without the thermostat set for cool. Just the fan. Does the fan run or does or does it hum? If it hums, the problem is the fan motor or capacitor.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 02-18-2016, 10:44 AM   #13
Chinese/Dometic Connection
We parked our 2015 Nitro in Deadwood last Sept. Turned on the air and left our 2 dogs inside to stay cool. Returned to find 98 degree temps as the "new" Dometic had failed. Have seen claims that a QC problem at the factory produced a series of bad AC's - nearly killed our dogs and ruined our trip. I'm saving this thread. If it dies again I'll be up on the roof checking capacitors with my multimeter! My thanks to those sharing their expertise and experience! We now wait to see if the AC blows cold before leaving.
LairdT is offline   Reply With Quote
Old 02-22-2016, 11:40 AM   #14
A/C wont kick on
Check for dirt dobber nest on fan blade blocking it from turning
WyomingJack
2015 CC Silverback 29 RE
2014 GMC 2500 HD
WyomingJack is offline   Reply With Quote
