I think you have two different 'issues', as the air conditioner basically works the 'same' regardless of generator power or shore power.
as for the generator, it's not uncommon for it to shut down if it overheats...ours has done this too, though if you restart it, it may run perfectly fine from then on. It's a mystery, and probably nothing to do with filters.
now, the air conditioner is a different story...as you stated that it 'used' to cool fine, but now seems to not. If you have time and can find a dealer, stop by and let them check out the cooling. If they deem that it's no longer cooling properly, it certainly could be a warranty repair/replacement solution...if you're still under warranty.
The Turners...
