I am not an RV A/C repairman. I have worked on residential, auto, and industrial A/C units. I have replaced quite a few RV A/C units on friends RV units. This is my opinion based on experience. Can an RV A/C unit that has a leak and has lost it's refrigerant be repaired, such as adding freon to an auto A/C unit? NO. RV A/C units are built as sealed units and have no ports to check low and high pressure and to add freon. They are basically throw away items when they go bad. There are some out there who will state that "tap valves" can be added to the refrigerant lines of an RV A/C so that pressures can be checked and freon added. Well, that is true. But--these tap valves are notorious for developing leaks within a short period of time. A really good A/C service tech can solder in ports, which probably will not leak for a long time, to service an RV A/C unit. Is this cost effective vs. a replacement unit? NO. I am more familiar with Dometic units than Coleman and a new 15,000 BTU Dometic core can be bought in the $550 range. A core does not come with the top cover, the Air Distribution Box, etc. According to the model # you posted your unit is a Dometic Brisk Air II 15,000 BTU model, which is a very common model. Changing out an RV A/C unit is not really that hard at all. Replacement units actually come with printed instructions and there are many videos on YouTube as to how to do this. The first thing to do would be to disconnect the shore power cord. $1500 to replace an RV A/C unit is a rip off IMO.
