Old 04-29-2016, 04:24 PM   #1
becca4vols's Avatar
AC Troubleshooting
This is our first trip out this year and it seems that our AC is not cooling. It is 86 degrees here in GA and I am hoping someone can help us troubleshoot or tell me to give it time to cool off. We have a Greywolf TT with a Dometic AC. Any help is appreciated!
becca4vols is offline   Reply With Quote
Old 04-29-2016, 04:33 PM   #2
What temp is the vent blowing out compared to the temp inside?
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 04-29-2016, 04:48 PM   #3
Flybob's Avatar
You don't say what year you GW is. Dometic has a batch of AC units that had corrosion issues and would leak. Contact your dealer as Dometic extended the warranty. As it is a Dometic issue, you may be able to have it replaced at any authorized Dometic shop.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-29-2016, 04:52 PM   #4
becca4vols's Avatar
@Toddupton it feels the same or maybe slightly cooler. I don't have a thermometer to tell.
@Flybob it is a 2015.
Old 04-29-2016, 05:22 PM   #5
Flybob's Avatar
Covered under extended warranty. Call dealer or Dometic.
TST Tire Monitors
2 100W solar panels
Old 04-29-2016, 06:16 PM   #6
Phenom's Avatar
I just had an issue with mine and discovered it was user error. It felt as if warm or barely cool air was coming from the vents. I found that I had the fan set to low instead of auto. The compressor would kick off when the required temp was met and then the fan would continue to run filling the trailer with humid near ambient temp air. Like a dog chasing it's tail, it didn't cool very well, I don't think the compressor could compete with that. Be sure the fan is set to auto.
Sean
'16 28DBUD
'16 2500HD Dmax
Phenom is offline   Reply With Quote
Old 04-29-2016, 08:53 PM   #7
Tfort's Avatar
They had to replace mine after our second trip because it developed a leak.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 05-21-2016, 07:39 PM   #8
becca4vols's Avatar
Waiting for replacement
Turns out ours was one of the faulty ones. Getting a new unit installed, at least it is covered under the warranty!
Old 05-21-2016, 09:11 PM   #9
Mr. Dan's Avatar
Thanks for reporting back. It helps us all when a solution is posted.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
