Old 07-17-2016, 01:24 PM   #1
TheLarks's Avatar
AC will not keep running on generator
Hi. We are brand new Georgetown XL 352 owners. We are trying to get the AC to run on the generator. It AC starts but turns off after approximately 30-60 seconds. Thanks for any advice. Debbie
TheLarks is offline   Reply With Quote
Old 07-17-2016, 06:44 PM   #2
No trouble with the ac when plugged in?
Mike
2015 Georgetown 351DS
Gohawks is offline   Reply With Quote
Old 07-17-2016, 07:49 PM   #3
TheLarks's Avatar
Correct. AC works great when plugged in.
Old 07-19-2016, 06:26 AM   #4
Is the genny popping a fuse on the genny?
rblack22 is offline   Reply With Quote
Old 07-19-2016, 12:34 PM   #5
NYDP77's Avatar
Are you just running 1 a/c unit and nothing else? Fridge set to gas? TV off?
DP
2013 Tracer 240 AIR
2014 Silverado 1500
NYDP77 is offline   Reply With Quote
Old 07-19-2016, 02:16 PM   #6
Your rig should have a 5500W Onan generator which will easily power the A/C unit. The generator is connected to an automatic transfer switch then to the electrical distribution panel. Since your AC runs fine on shore power but starts then quits on the generator I'd strongly suspect a problem with the transfer switch.
I'd get an AC voltmeter and check the voltage on both legs of the power feed to the circuit breaker box. You should read 120V from each "hot" wire to neutral and if you see a significant change when the AC shuts off (ie one leg goes to 0V) the problem lies between the generator and the distribution panel, leaving the transfer switch and the wire connections to it as the culprit.
Phil
pmsherman is offline   Reply With Quote
Old 07-19-2016, 02:17 PM   #7
I have the diesel generator. I have to let it run for about 5 minutes before the air conditioner is turned on. I also put the fan on so it has a load or else it does exactly what you are saying if I go right to air conditioner. It cuts out.
Sent from my SM-T810 using Tapatalk
hifromkate is offline   Reply With Quote
Old 07-20-2016, 05:45 PM   #8
nodrawers's Avatar
AC on generator
I just got back from 7 days boonbocking in 100 + degree weather AC on small generator. No problem with this setup. AC also starts much easier on shore power.
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
Days camped 2018 136
nodrawers is offline   Reply With Quote
Old 07-20-2016, 05:59 PM   #9
nodrawers's Avatar
AC on generator
sorry no pic.
Old 09-08-2016, 12:34 PM   #10
AC shutting down on generator power
Are you still having a problem. I had a similar problem with my AC running for a while on generator power and than shutting off after 15 to 20 minutes. I have an AC ceiling vent in bedroom just above thermostat which was blowing on thermostat. I closed off the ceiling vent and now runs fine.
kenjoan is offline   Reply With Quote
Old 09-08-2016, 09:03 PM   #11
TheLarks's Avatar
Thanks for the info but we did get the problem fixed. It was a bad board in the generator. It was Under warranty so just cost us the inconvenience and getting hot while driving.
Oh but we did get a rock to windshield while driving home from Cummins.
Mitch & Debbie
Maggie, the Wonder Dog
2015 GeorgetownXL 352
2016 Jeep Wrangler Unlimited
air conditioner, generator
