Old 06-23-2018, 12:17 AM   #1
Evereddie's Avatar
AC will not run
First off let me say this help is needed for a SOB. Brother bought a 2011 Tiffin Motorhome. Bought in Charleston and drove to my house in Winston Salem area several weeks ago. He is coming Sunday to drive it to Chicago where he lives. Everything went well on trip here. Ran generator and front AC to help cool while driving. Today I thought I would check everything out and found that the front AC was not working. (Coleman Mach "polar" style heat pump) Testing on generator, like when we drove it here. Back AC runs fine. Front AC which is also a heat pump will not even run the fan. I did find a tripped breaker for the AC. Don't know why that is. A question I have is will the fan run even if it may be low on freon. Maybe something wrong with the transfer switch. I have plugged it in to keep batteries charged.
Any ideas?
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 06-23-2018, 09:02 AM   #2
SeaDog's Avatar
Freon has no effect on the fan with that said if the compressor is tripping the brakee you will not get power to the compressor or fan, they both run off the same contactor. Make sure you actually have power going to the unit.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-23-2018, 09:52 AM   #3
Evereddie's Avatar
Originally Posted by SeaDog View Post
Freon has no effect on the fan with that said if the compressor is tripping the breaker you will not get power to the compressor or fan, they both run off the same contractor. Make sure you actually have power going to the unit.
Thanks. Ya, on my camper the fan will run if you switch the thermostat for the fan to ON. Breaker doesn't trip any more. Just found it tripped once when I first started to investigate. Today I'll do some voltage measurements. Also see if the compressor runs even though the fan isn't.
2018:16
Total 239
Old 06-23-2018, 10:03 AM   #4
cavie's Avatar
All systems do that. If the compressor runs without the fan the unit will freeze up. You will get no cold air.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 06-23-2018, 05:21 PM   #5
lakewood90's Avatar
There is a forum for Tiffin owners at A Part of the TiffinRVNetwork • Index page where you might be able to get more information. It is a wealth of information on Tiffin motorhomes along with all the various chassis used in Tiffin motorhomes. It is similar to the FR forum in that it is owners and is not connected to Tiffin. You might find what you are looking for on that site. Good Luck!
Tiffin Allegro Bus 43QRP DP
(Sold)2016 Sunseeker 3010DS
TOADs: Honda CRV and Jeep Grand Cherokee Overland 4 x 4
lakewood90 is offline   Reply With Quote
Old 06-23-2018, 05:22 PM   #6
lakewood90's Avatar
I see the website did not come through for some reason. It is:
www.tiffinrvnetwork.com
Hope it comes through this time.
Old 06-23-2018, 07:36 PM   #7
Evereddie's Avatar
Thanks everyone. It is fixed. Darned starting capacitor for the circulation fan. Lost a little time when the breaker on the generator tripped and I didn't know it and was testing without power. Bought a new capacitor locally and all is good. Thanks for all of your help.
Now back to my Rockwood.
2018:16
Total 239
