Old 07-26-2019, 08:51 PM   #1
AC won't turn back on
So I just bought a brand new Sabre 5th wheel. The A\C is blowing nice and cold for a while then shuts off. As as the temp goes up inside the camper you'd expect the unit to kick back on but it won't. The only way I can get it to turn back on is if I set the thermostat to off, wait a few seconds, then go back to cool. Both the front and rear A/C units are doing the same thing. Any ideas?
pspc271 is offline   Reply With Quote
Old 07-26-2019, 09:05 PM   #2
Chris Pastuzyn's Avatar
Welcome to the forum from New Jersey, Just got back from Delaware, Try taking the AC off auto, run on either low or hi, This should keep the fan running while the compressor cycles on/off.
Chris Pastuzyn is online now   Reply With Quote
Old 07-26-2019, 10:37 PM   #3
In my experience, you have a bad thermostat. If it's an analog, replace it with a digital (even if it's not bad).
2011 Traverse LT, 3.6L, FWD
Old 07-27-2019, 06:53 AM   #4
Head Rambler
If you have a Dometic single zone thermostat, you can try initializing it. That works sometimes, but other times it's as Roo said, the thermostat is defective.
Gotta go campin!
Old 08-06-2019, 12:23 AM   #5
This is a known issue with some dometic ac's.
It happens so often dometic does even require a repair sheet. They recommend installing their "repair it" which includes a new control box, thermostat, and for some odd reason new a/c mounting bolts.
Side note: If anyone has issues with their capacitive touch tstats, its the same thing, no questions asked, dometic will send you a new face plate for the tstat.
email is offline   Reply With Quote
Old 08-06-2019, 08:46 AM   #6
Maybe a related question.... Can the T-stat be set to fan only with no heat or ac?
Mine has 4 mode stops along the menu path. Hit the left MODE and it goes from OFF to FAN (Low/Auto/High), HEAT and COOL. It seems that I touch the mode button to select the fan mode, and that is selecting the fan mode for the heat or cool mode. It does not seem to have a stand alone fan to circulate air.
I really wish that the AC or furnace had a fan/vent to exhaust hot air out and pull cooler outside air in as the evening arrives. Am I missing something, or is that not an option on these systems?
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,075 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,546 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
2019 Kawasaki Mule Pro DX W/EPS and Yanmar Diesel 2,000 LB towing and 1,000 payload.
Larry0071 is online now   Reply With Quote
Old 08-08-2019, 03:41 AM   #7
CincyGus's Avatar
Depends on the unit. Mine allows Fan, HI Cool, LOW Cool and HEAT.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
