Old 02-05-2015, 03:11 PM   #1
zs325RES's Avatar
Accessing behind the switch panel??
I've been wanting to get behind my switch panel on my 325RES, but can't figure how it comes apart.
This is the panel behind the small door with dark glass which has the light switches, WH control, slide switches, tank monitors, etc.
I've got some mods in mind, and wouldn't mind straightening up some of the crooked switch installs from the factory.
The whole assembly looks to be totally permanent, and I don't really want to start hacking if I can get it apart otherwise.
stock photo:
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 02-06-2015, 10:33 AM   #2
Too Tall's Avatar
Mine is not behind a door but it would have to come out from the front. Do you have screws on the panel?
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 02-06-2015, 01:55 PM   #3
zs325RES's Avatar
That's the thing, there are no screws or an obvious method for assembly. I can't imagine they could have wired it all up then fastened the whole cabinet to the wall.
It's in storage now, but I recall there being some 1/2"x1/2" trim pieces that may be holding the panel into the cabinet. I might find a way to get into it if I remove this trim, but I would likely destroy the trim when removing it. It wouldn't be to much to replace the trim with some properly stained wood trim if I wanted to take that chance.
Old 02-06-2015, 02:00 PM   #4
Mojojojo's Avatar
Very GENTLY try to pry the corners out one at a time to see if there is any give, may be a pop in type of bracket on the back.
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-07-2015, 09:21 AM   #5
Too Tall's Avatar
Yea, it could be like the radio where there is a clip-on trim on each side which snaps off by sticking a small screw driver in the hole and it exposes the screws. Some of those things can be confusing but it was definitely not wired before so there must be a simple way to get it off from the front.
I just pulled my stereo apart as I installed an XM radio and has to get to the 12 volt cigarette light plug. These things are usually simple as hell once you figure it out. When you get behind some of these panels, you wish you would have not seen the crap they leave behind, cuttings, sawdust etc... My AC was wired wrong, I rewired it myself. My water tank was bending the brackets and ended up fixing it myself after a half ass job by the dealer.
USMC 68 -70
Old 02-07-2015, 09:43 AM   #6
B and B's Avatar
Too tall. I saw the same mess and added 20 tywarps to strain relief the wires and neaten stuff up. I added a Sirius to my unit also Sat audio in to the Genesis and TV audio out to Genesis In for off air. The bezel on mine was broken from factory so mine was easy to figure out.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 02-08-2015, 05:23 PM   #7
Roger and Paula
Call the tech support people and ask them. They have proved veryhelpful to me
Rstrahan is offline   Reply With Quote
