Old 07-14-2016, 01:42 PM   #1
Captain America's Avatar
Adding SPP6 hard start capacitor to Dometic 15000 btu AC
Can someone point me to a thread about this? I have searched and found threads about coleman and dometic 13500, but not the 15K.
Thinking about adding a hard start.
2011 Wildcat 32QBT
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor
Jack of all trades, Master on none
Captain America is online now   Reply With Quote
Old 07-15-2016, 12:55 AM   #2
Why?
Kuba is offline   Reply With Quote
Old 07-15-2016, 08:13 AM   #3
Because I run AC off generator and any extra start up help won't hurt. It's only $12 and two wire hook up.
Why not?
2011 Wildcat 32QBT
Old 07-15-2016, 08:33 AM   #4
If I am not mistaken it was installed the same as it was on the 13.5 unit. Did it to ours 2 years ago, and the only thing I remember being different was the box was slightly smaller and it was also a tight fit length wise.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 07-15-2016, 11:19 AM   #5
Learjet's Avatar
Are you sure you don't have one already?
-2013 Ford F250 XLT 2wd Crew Cab 6.2 with 3.73
-2015 Wildcat 317RL
-B&W Patriot 18k, MorRyde, Timbrens
Learjet is offline   Reply With Quote
Old 07-15-2016, 01:16 PM   #6
I don't believe so. I only saw one oval shape capacitor. Something like this, I just briefly glanced at it.
2011 Wildcat 32QBT
Old 07-15-2016, 01:34 PM   #7
Iwannacamp's Avatar
If it has has a three terminal run capacitor... the terminals will be marked on the top of the capacitor. It should have a C term(voltage in... the one to use)), a Herm term(compressor..the one you want to use) and a F terminal(fan... pay no attention to this one). One terminal each goes on the Herm and common terminals. Polarity is not important. If is is a 2 terminal run capacitor then it is easy.
PS: these could be hot(charged). Use your meter to read the OHMS on the terminals several times reversing polarity as you proceed. This will discharge the capacitor safely. Don't forget to turn the power off.
Our new 5er 10-26-16
Days camped 2016 8
Old 07-15-2016, 01:51 PM   #8
Blog: RVroadtripper.com
hbillsmith's Avatar
Back in 2015 I called Dometic customer service and asked about adding a Hard Start to my 15K and they said it was necessary because they now are already engineered for Hard Start. I've been running both my 15K and my 13.5K on generator multiple times and have experienced no issues. They seem to run fine. Once, when it was very hot and the 2 units had both cycled down, they attempted to both come back on at the same time. The generator shut down with overload. I restarted the gen, restarted the 15K, waited about a minute or 2 and restarted the 13.5k and they ran all the rest of the day just fine.
Most of the time, we only run 1 A/C at a time. Bedroom 13.5 while we are in the Living Room and then 15K Living Room while we are in the bedroom at night. This puts the noise furthest away.
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover
Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball
LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote
6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard
Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 07-15-2016, 05:39 PM   #9
Why not?
What generator do you have? And yes, capacitor will only help.
Old 07-16-2016, 08:10 AM   #10
Anyone tried the EasyStart by Micro Air?
This is what they claim:
Test: 16,000 Btu 115v Compressor
Before: EasyStart installed:
- 72 amps peak inrush current on mains power
- Would not start on Honda 2000i portable generator
After: EasyStart installed:
-32.5 amps peak inrush current on mains power
-Started easily from Honda 2000i portable generator
I'd love to run my 13.5 with my Honda 2000, but would like someone else to confirm that it works before I do.
mnoland30 is offline   Reply With Quote
500, dometic
