Old 09-28-2016, 08:27 PM   #21
have the same awning and the same problem. ive hade to make two new pcs for it because they have bent. solved problem by using awning poles and tie downs.
m hill is offline   Reply With Quote
Old 09-28-2016, 08:40 PM   #22
The poles solve a lot of problems along with the deflapper poles.
Old 09-28-2016, 08:43 PM   #23
Originally Posted by Decon Blue View Post
Mines just the opposite, I tilt mine down and it drifts up. :-(.
I've got the same darn awning, except the electric model. It is indeed a Solera. I don't know how they can call those things adjustable. It's pretty much a one-position deal. I can pull those adjuster arms down all day long and the thing just returns to its original position. I've tried lubing and tightening everything in sight. The ONLY thing I can see they are good for is if you leave one arm locked straight and bend the other side a little so one side is pitched slightly lower, it'll allow the rain to run off without collapsing your awning. You're not going to be blocking any horizontal sun with it or anything, though.
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 09-28-2016, 09:41 PM   #24
Usually Confused Member
emm-dee's Avatar
Too much lube is not good. I talked to Lippert folks and they said clean off the lube stuff and snug the main bolt that attaches the adjusting arm ONLY.
Mine works just fine. Can stop it in any position I want and then set the awning poles (homemade poles).
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 09-29-2016, 08:02 AM   #25
Wolverine 1945's Avatar
If all else fails,,, Awning Pols & Tie Downs !!!
LOL !!!
Wolverine 1945 is offline   Reply With Quote
awning
