Old 07-23-2011, 06:46 PM   #1
Air conditioner
I really understand it hot out side I just purchased a new xlr toyhauler I feel that that air conditioner in not working proper it takes all day for it to cool down and then it's still warm inside any suggestions?? 600 miles from home
dgreene66 is offline   Reply With Quote
Old 07-23-2011, 08:21 PM   #2
If you search around here there is a thread from someone that modified the airr supply duct part of the system (shaving styrofoam better into a taper for better airflow) there might be some information there to help.
Days/nights camped in 2011 (seasonal site)
5 nights
8 days
2005 30' Wildwood LE with 2 slideouts
rick_h is offline   Reply With Quote
Old 07-23-2011, 09:26 PM   #3
Have you opened up the vents on the underside of the air conditioner? The ducting is very restrictive, so I always open those vents to let the air conditioner breath as freely as possible.
You also must remember that your camper is a big, poorly insulated box, and is not easy to cool at the best of times.
How big is your camper? Did you get the larger air conditioner?
Old 07-23-2011, 09:58 PM   #4
jimh's Avatar
well, i don't know how to past a link so i will hand write it in.
http:http://www.forestriverforems.com/for...75-a-1349.html
sense i probably have a couple of typo's in there, it was posted on 6-1 by Daisy boykin. under modifications and updates.
this is the one rick-h is alluding to i believe.
jimh is offline   Reply With Quote
Old 07-23-2011, 10:02 PM   #5
jimh's Avatar
well, clicking on the link didn't work for me so u will have to use the alternate method.
Increase ac vent air flow by 75%
try the above. see if that works.
Old 07-23-2011, 11:07 PM   #6
Yes it is the big air conditioner this camper is 43 feet we have a vent less in the bed room but the center has been very hot I'll take any input thanks new to the game
Old 07-23-2011, 11:37 PM   #7
rrdrtravelers's Avatar
Ours is 40 foot and the same situation. I figure it's just too darn hot to cool that big boy down when it's over 100 outside and close to that inside before trying to cool it off. At first we wondered if ac wasn't working properly but our first night in it and we froze bc it got so cold. This extreme heat is hard on any ac. I suggest reading the modification link the previous guys are referring to. It can help.
2011 Cedar Creek 36RE
2002 Ford F350 Crew Cab 4x4
rrdrtravelers is offline   Reply With Quote
air conditioner
