Old 12-29-2015, 05:01 PM   #1
Air conditioner
I have a 2015 cruise lite 28' bunk house. We had to replace the AC 3 months after purchase, due to it freezing up and leaking inside the camper. Once replaced the new unit is much quieter. We haven't really used to much this year due to some family issues, but used it 2 weeks ago at the house plugged in to a 120v outlet, nothing else runs on that outlet. 4 hours after running it again started to leak in the trailer, no cold air. Thought maybe from door opening and closing a lot here in Florida lots of humidity made it leak. Well just used it this past weekend and this time all door closed but a couple of times and at 5 AM the AC was froze up again and dropping ice into the fan. Frustrated.. What are the warranties on the AC. We had it replaced at Camping World in New Port Richey Fl. Where we bought the unit. Any ideas????.
Mcauchon1 is offline   Reply With Quote
Old 12-30-2015, 07:45 AM   #2
Head Rambler
It sounds like the freeze coil isn't clipped to the evaporator. I had that problem in an older unit and found that the freeze control was just laying loose in the unit. Once I clipped it to the tubing loop on the evaporator it quit freezing up.
I also found leaks between the discharge and return and sealed those with foam backed aluminum tape.
Gotta go campin!
Old 12-30-2015, 08:06 AM   #3
Flybob's Avatar
I found that on ducted units if it is very humid and you run the AC on low fan, it will occasionally freeze up and shut down to thaw. My solution was to open the quick chill vent (on inside portion of AC unit itself) slightly which allows more air flow over the coils thereby preventing freeze up.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-30-2015, 08:19 AM   #4
Oaklevel's Avatar
Are you running it on a 120V outlet with an adapter and on a 15A breaker at the house ?? Possible you are running it at low voltage, not a good thing.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 12-30-2015, 09:11 PM   #5
Never thought to see what size breaker I have it plugged into.....let's say it is 15 amp what damage could happen??
Old 12-31-2015, 04:52 AM   #6
Oaklevel's Avatar
Usually it is not recommended to use adapters and plug into a house outlet for the AC. If you have a dedicated 30A 120V RV outlet installed you would be fine. Someone hopefully will come along & explain it better than me but if you have low voltage running to the AC you can damage the AC compressor. The other issue is possibly over heating the wiring.
1966 Mustang GT
1986 Mustang SVO
Old 12-31-2015, 05:02 AM   #7
Oaklevel's Avatar
As far as to AMPs here is a helpful list that Turbs posted some time ago
Wattage % Volts = Amps
Amps X Volts = Wattage
One other thing to keep in mind is many RV appliances require more amps to start the appliance than they do to run the appliance. A roof air conditioner can draw 16 amps to start, but may only use 13 amps once it is running.
120 Volt AC Amp Ratings
Appliance or Electronic Equipment Estimated Amps
Air Conditioner (X number of A/C) 12-16 Amps
Blender 5-6 Amps
Coffee Maker 5-8 Amps
Compact Disc Player 1 Amp
Computer (Laptop) 2-3 Amps
Converter 1-8 Amps
Crock Pot 1-2 Amps
Curling Iron <1 Amp
Drill 2-6 Amps
Electric Blanket 0.5-1.5 Amps
Electric Fan 1 Amp
Electric Water Heater 9-13 Amps
Electric Skillet 6-12 Amps
Hair Dryer 5-12 Amps
Iron 5-10 Amps
Light (60 watt % 120V) <1 Amp
Microwave 8-13 Amps
Microwave (Convection Oven) 13 Amps
Refrigerator in AC mode 5-8 Amps
Space Heater 8-13 Amps
Television 1.5-4 Amps
Toaster 7-10 Amps
Vacuum (handheld) 2-6 Amps
VCR 1-2 Amps
Washer/Dryer 14-16Amps
12 Volt DC Amp Ratings
Appliance or Accessory Estimated Amps
Aisle Light 1 Amp
CO Detector 1 Amp
Fluorescent Light 1-2 Amps
Furnace 10-12 Amps
LP Gas Leak Detector 0.5 Amp
Overhead lights (Per Bulb) 1 Amp
Porch Light 1 Amp
Power Roof Vent 1.5 Amps
Radio/Stereo 4 Amps
Range Hood (Fan & Light) 2-3 Amps
Refrigerator (LP Gas Mode) 1.5- 2 Amps
Security System 1 Amp
Television (12 volt) 4-5 Amps
TV Antenna Booster <1 Amp
TV Antenna Booster 12 Volt outlet Up to 8 Amps
Variable Speed Ceiling / Vent Fan 4 Amps
VCR Recorder / Player 2 Amps
Water Pump 4 Amp
1966 Mustang GT
1986 Mustang SVO
Old 12-31-2015, 06:41 AM   #8
TURBS's Avatar
Do you have any a/c vents closed ?
2 things are common if your a/c freezes up.
1) frost sensor off or faulty.
2) vents are closed and air flow is low.
Open quick cool dump slightly for more air flow help.
Old 12-31-2015, 06:43 AM   #9
TURBS's Avatar
Frost sensor
air conditioner
