Old 07-20-2019, 11:55 PM   #1
BigRedBill's Avatar
Air Conditioner -- Fan doesn't shut off
Hello all. We have a 2012 Surveyor Select travel trailer. The air conditioner turns on and cools the camper down just fine. Problem is that, even when the thermostat is set on "auto" for the fan, it never shuts off. Was a major problem when we were up in the mountains and it was cold at night. Turned on the heater and the air conditioner fan was still blowing.
Is this as simple as replacing the thermostat?
2012 Surveyor Select SV-294
2008 Ford F-250 Super Duty Crew Cab 6.8L V10
BigRedBill is offline   Reply With Quote
Old 07-21-2019, 05:53 AM   #2
Do you here the compresor kick on and off?
If so everything's working propperly.
2012 new to you ?
Fans always run unless it's a central a/c unit like in a house
Tblt44 is offline   Reply With Quote
Old 07-21-2019, 08:39 AM   #3
A32Deuce's Avatar
Does it have high/low fan speed. If so try one of them on fan speed side then go to AC and see if it shuts down.
A32Deuce is offline   Reply With Quote
Old 07-21-2019, 10:44 AM   #4
Failure is my business
2Evil4U's Avatar
One of my Machs digital controllers failed opposite that. The fan would stop but the compressor would stay running. I just swapped back to the analog wall controller and it's fine.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is offline   Reply With Quote
Old 07-21-2019, 10:48 AM   #5
Flybob's Avatar
AC is set to auto, what is the fan set at. It needs to be auto also.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-21-2019, 11:14 AM   #6
I have the opposite problem. my a/c does not run on auto and will only work on high. I have an appointment for tue to have a tech look at it. dometic customer serive told me it prob a control board issue.
Kimber45 is offline   Reply With Quote
Old 07-21-2019, 02:10 PM   #7
BigRedBill's Avatar
2012 new to you ?
Not new to me. We bought it new and just started experiencing the problem. The compressor turns on -- blows out cold air. It just doesn't shut off. If you turn the heat on instead, the furnace blows hot air out of the floor vents and the air unit's fan is blowing cold air out of the ceiling.
Old 07-21-2019, 02:39 PM   #8
A32Deuce's Avatar
Set your thermostat to auto, then when you use the heat the ceiling fan won't run to circulate the air.
Old 07-21-2019, 04:40 PM   #9
DavidBo's Avatar
Is that a factory thermostat? Many times folks upgrade to a residential style digital unit and the switchology is different, the common outcome can be pretty much what you described.
Some folks get around this by adding an extra toggle switch, but I find it easier just to change over to a Dometic/Coleman factory digital thermostat.
No idea if this applies to your case, but worth checking out.
DavidBo is online now   Reply With Quote
Old 07-22-2019, 11:29 AM   #10
rlh1957's Avatar
Has it always done this? Thermostat could be wired incorrectly, or the thermostat switching contacts are bad.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 07-22-2019, 11:34 AM   #11
Flybob's Avatar
See page 7 on Fan settings.
TST Tire Monitors
2 100W solar panels
air conditioner, fan
