Old 05-13-2019, 02:47 PM   #1
Air conditioner, possible problem
Dometic roof air conditioner on a travel trailer. Is it common if the temperature is cool outside 67 degrees that the unit will not through cool air. I was just testing unit and it seems not cooling, inside 77 degrees. I don't know if this is a problem or it was to cool outside for unit.
tomahawk246 is offline   Reply With Quote
Old 05-13-2019, 04:26 PM   #2
Failure is my business
2Evil4U's Avatar
Typically, if it's cold outside and the unit runs too long it can ice up and then it won't cool.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is offline   Reply With Quote
Old 05-14-2019, 03:54 AM   #3
CincyGus's Avatar
To be honest, I've never run the AC for more than 60 seconds when it was below 80 outside. And then only once when I was buying a used Camper and just wanted to see if it would blow cool air. Was the same thing in that the inside of the camper was warmer than the outside air so it fell cooler so I turned it off. AC worked fine once it was hot enough to use it (I bought the camper).
Most things I have read on RV AC say that don't expect it to maintain a temp any more than 15-20 degrees cooler than the outside air if working in optimal conditions. I don't think I would sweat it until it got hotter and it wasn't cooling properly.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
air conditioner
