Old 06-25-2012, 06:09 AM   #11
The first thing you should do is turn the breaker of to the A/C unit then check the wiring, but it sound like the relay is stuck. The units we have here are the same that you have but they are "low profile units" the relay on ours are on the control boards and in order to replace the relay the board has to be replaced.....Do Not Let The Compressor keep running because you could damage it.....
air conditioner
