Old 05-25-2011, 05:26 PM   #1
cmhbob's Avatar
Air Conditioning
We've got a problem with our Dometic Duo-Therm AC in a Sandpiper 35Loft.
The compressor runs constantly as long as there is power from the circuit breaker, but the fan only runs occasionally, like the fan is responding to the thermostat, but the compressor isn't. Even with the thermostat off, the compressor runs.
Thermostat? Circuit board on the AC? Compressor?
Any ideas to troubleshoot or attempt a quick fix before we go for service? We're in Georgetown, KY this month.
Bob Mueller | Fulltiming family of 9 since Feb 2011
More About Me
cmhbob is offline   Reply With Quote
Old 05-25-2011, 06:29 PM   #2
onetonford's Avatar
More than likely circuit board has relay for compressor and it is stuck possibly from points arching and welded together . To test you would need to disconnect the yellow wire from T-stat and if when breaker is turned back on and compressor still runs then relay is bad. If it dosn't run than T-stat is bad.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 05-25-2011, 07:55 PM   #3
MtnGuy's Avatar
Is it possible for the thermostat to be wired incorrectly ?? The compressor wired to the fan switch, and the fan wired to the AC switch ??
Old 05-25-2011, 08:42 PM   #4
Villa Estate 392FLFB
The_Stuff's Avatar
pull the cover down inside (overhead unit right?) and check wiring. one was loose on mine and it did same thing.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 05-25-2011, 10:09 PM   #5
cmhbob's Avatar
Mtnguy, it ran fine for a while, then this popped up about 2/3 of the way through our stay in TX. The drive from TX to PA then to KY over two weeks hasn't changed anything.
Weather is spotty here for the next few days so it may be a while until I can check anything outside. I'll check the thermostat tomorrow though.
Note to self. Next rig MUST have dual AC. A single 15k BTU just doesn't cut it.
More About Me
Old 05-26-2011, 04:10 AM   #6
Bob,how does it work for repair work on a unit with (9) people living in it full time? Any time our unit has been to a dealer for repair,(many) they want it early and is always a few days,for pick up. What do you do with the food in the refrigerator? How does the battery stay charged? None of the dealers have hooked up our unit to shore power,ever! Youroo!!
Old 05-26-2011, 07:39 AM   #7
Herk7769's Avatar
The downside to the lifestyle for sure.
Breakdowns with the TV or camper can really put the damper on things. My buddy just cracked the pinbox attachment to the trailer frame on his 5th wheel Montana while traveling through VA. They have to remove the entire nose of the camper and cut a giant hole in the bedroom floor to get at the crossbeam to weld up a repair. 5 weeks in the shop minimum.
He is an astronomer and travels with 2 giant telescopes as well as all his gear. Had to rent a U-Haul trailer and buy a WD ball hitch to get his stuff home.
The hazards of running "just a tad heavy" because they are "over-designed." He was 400 pounds heavy on the pin for several years.
HAM CALLSIGN - KC3FFW
Old 05-26-2011, 08:10 AM   #8
cmhbob's Avatar
We've been fortunate so far (only been OTR since Feb) and haven't had any major issues. We bought onsite repair coverage, too.
More About Me
Old 06-07-2011, 05:05 PM   #9
cmhbob's Avatar
Bing! Tested it today finally. Anyone know where the relay is, or if it's user-servicable?
More About Me
Old 06-25-2012, 12:44 AM   #10
I know this thread is a bit old, but as far as repair work with full timers go, we had full timed in 2008 for a year and just started again. With our fourwinds TT, we had our warranty coverage and then extended warranty as well, but I contacted them and told them we were in the unit and displacement would be difficult if we were to have to turn the unit in, and they authorized me to get a quote (subsequently accepted and approved for repairs) from a company here in Maryland who is a Mobile RV Repair and does his work on your location. Only difference was, I had to pay him the cash (he would submit for me if I wanted to but easier for me as I already had been talking to the MFR and Ext Warranty Company) and they reimbursed me the cost of the repairs. Bottom line to them was, they wanted to know the parts cost he was going to charge (or get it from them) and the labor he would charge for his work. Since his rates were acceptable as equivelant to the dealers rates, they covered it with no issues.
2012 Ford F-350 6.7L CC SRW w/FX4
2013 Forest River Sierra 365SAQ
Beausdog is offline   Reply With Quote
air conditioner
