Old 05-30-2011, 07:30 AM   #11
2011 Crusader 320RLT
The ac unit is a Dometic model number 541916A701C0. It is ducted through the camper. The fan sounds like it comes on in fan mode. Its almost like it has an obstruction that keeps the air from blowing.
We bought the extra warranty. It is a holiday, so, will someone come to fix it? We are still in our driveway!
lilspiritus is offline   Reply With Quote
Old 05-30-2011, 08:45 AM   #12
M109Rrider's Avatar
You do know a/c blows from the ceiling vents and heat only blows from the floor vents right? I only ask because if your not familiar with campers sometimes people don't realize this. If you don't have air blowing from the white round ceiling vents, look in the ceiling above the microwave and above the table. Those rectangle louvers are the air inlets. Under the louvers are filters. You could take the louvers off and check for obstructions there.....make sure the hole is cut (unlikely but I've heard of it before)
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 05-30-2011, 08:59 AM   #13
Thanks M109Rider. I will check. It wouldnt surprise me. They did not open the valves to the hot water heater and we had to crawl up inside and open them up. We will check that. Thanks!
Old 05-30-2011, 09:38 AM   #14
Nope. That wasnt it.I know the ac is working. I can feel like a whisper of air through the vents and it is cold. The fan must not be kicking in, ??
Old 05-30-2011, 10:25 AM   #15
M109Rrider's Avatar
Sounds like the fan is doing something, did you try turning the fan to high?
Jason and Billie
Old 05-30-2011, 12:06 PM   #16
jimh's Avatar
This may have already been suggested but...next to ur air into the ac unit, do u have a slide vent u can open? Try opening and see if u get air.
U can put a piece of paper on the intake(filter} grill and see if air is being pulled in. if it isnt, id try and see if the squirl cage fan is turning. Its possible the fan wasnt tightenef on the motor shaft (ive seen this one time).
Even if there is a blockage, when u open the quick cool vent, air should move. (the quick cool is the slide next to the grill covering the filter). My unit is old...they tend to change them.
jimh is offline   Reply With Quote
Old 05-30-2011, 12:16 PM   #17
M109Rrider's Avatar
Different kind of A/C. Ours use a ducted a/c return like a home central air unit.
Jason and Billie
Old 05-30-2011, 02:14 PM   #18
jimh's Avatar
Sorry abt tt, I did repeat sug in either post 5 or 6.
What abt checking the air into the filter for flow? If it wont hold a piece of paper, id try and locate that fan and see if it is turning.
Where is ur return filter located? Did I read earlier the unit was on the roof?
Is it also a split unit like home units?
Old 05-30-2011, 02:58 PM   #19
M109Rrider's Avatar
The filters are under the 2 return louvers on the ceiling
Jason and Billie
Old 06-02-2011, 07:28 PM   #20
Well. It is headed to the shop tomorrow. They think there is a blocage. Thanks for all the suggestions.
air conditioner
