Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Forest River Tech Talk > General Tech and Repair
Old 05-29-2011, 04:25 PM   #1
2011 Crusader 320RLT
2011 crusader, ac runs but dont blow air-help!
This is our first trip out with our new 2011 32 ft crusader. The ac turns on but does not blow air... can anyone help? Is there something to check?
lilspiritus is offline   Reply With Quote
Old 05-29-2011, 04:43 PM   #2
BOBFIDY's Avatar
Stupid question to your question...but...is the vent/grid open to let air out?
Is there air going to the rest of the rig? Or maybe your rig does not have vented A/C.
Trying to help you with helped us.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
NIGHTS CAMPED 2010...33...2011...67...2012...72
IN 2013....8 nights in 2 trips so far
HURRY UP FROG BRANSON AND GOSHEN 2013
FROG MEMBER SINCE BRANSON #1 2011
BOBFIDY is offline   Reply With Quote
Old 05-29-2011, 04:51 PM   #3
BOBFIDY.. not a stupid question.. where is it? It is brand new, and I havent checked, but that is what I asked my husband. Where would we open the vent/grid? It is a 2011 Crusader fifth wheel.
The dealer had not opened the valves to let water go to the water heater either, so I am not surprised if this isnt open either. Thank you for helping. We had an outback before. Never had these kinds of issues on a new trailer before. The outback was ready to roll - We are supposed to leave tomorrow, but - we will see now!
Old 05-29-2011, 04:55 PM   #4
It is a central ac unit on top (not inside) the unit. Air vents have been turned, no air.
Old 05-29-2011, 05:25 PM   #5
Air Conditioning running but no air from vents
We have a 2011 Crusader. We can hear the ac running, but no air coming from vents. Even with the thermostat set to vent, no air. Vents do not close, just directional. Any other suggestions? First time going out,.. figures it would be on a holiday weekend with no open dealerships.
Old 05-29-2011, 06:22 PM   #6
grhodes50's Avatar
On the AC itself there is a vent. If it's open it will cut the air flow to your other vents.
Let me rephrase that. It won't cut the air flow to your ceiling vents, but it will allow enough volume of air to come out at the AC vent itself that little or no air will reach the ceiling vents. It's what they call the Quick Cool feature.
I'm not sure if this is your problem or not, but you might check to see.
Gary & Trish
2011 LaCrosse 303 RKS Touring Edition : 2007 Flagstaff 206ST MAC Series
2010 F-250 XLT : FX4 : CC : SB : 6.8L V-10 : 4/10 Gears
2013 Nights Camped - 0
Old 05-29-2011, 09:16 PM   #7
You didn't say what model your air was, but since you mentioned vents don't close, I will ASSUME a non ducted AC. Take the cover off from inside, two one quarter-turn screws on one end, on most models. Now turn on the AC. Do you feel air moving? Should be blowing straight down. If not you may have a fan problem. You might be able to see the fan to tell if it is running. If no fan, then need to continue, but verify the fan is running first. (you mentioned you hear it running, but you may be hearing the compressor). Post back, and include brand and model of AC).
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-29-2011, 09:56 PM   #8
M109Rrider's Avatar
The crusader a/c is different, it's completely ducted and doesn't penetrate into the ceiling like most others (no quick cooldown). It has recirc inlet almost like a home a/c in the ceiling above the kitchen. Sounds like the compressor is running but not the blower motor. I'd check the fuses/bkr. Maybe turn off/pull fuse and turn back on. Could be a thermostat issue too. The thermostat is kinda tricky to use if your not familiar with it. Using the thermostat you can manually turn the fan on. Sorry I'm not more help.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 05-29-2011, 10:03 PM   #9
M109Rrider's Avatar
Had to look at mine to refresh my memory. There is only 1 breaker. If you put your thermo in fan mode then use the +/- buttons to select between hi lo and auto. put in hi/lo and see if fan runs. If it does I'd venture to say it's a problem with the thermostat....i.e. it's not tell the blower to come on when in A/C mode. There's a small delay for the fan to turn on and turn off.
Jason and Billie
Old 05-29-2011, 10:53 PM   #10
grhodes50's Avatar
Thanks Jason. I learn something new everyday. My problem is tryin' to remember what I learned.
Gary & Trish
air conditioning
» Online Users: 937
189 members and 748 guests
2003rocky, 38FLCamper, avolnek, B47, bclemens, bigbadbrad, BigJohnD, Bjs306, bnak654, Bob DeWitt, bob34787, bob7794, boowho, bradnailer, Brazealnut4, Buckeyecmpr, buckster, Buffalohunter, Cacooze, calsmith1, Camping Buddys, canmannc, Cedar, checca, Chip411, chorizos338s, D-mo, DAISY BOYKIN, Dalroo, DAREK.NIEUWSMA, darkcloud, DDC, Deer Camp RVer, dimurrrw, dkwin1, drc343, dt82153, dtolar, elind, Emptypockets, ependydad, f1100turbo, FarFromStock, fmc, fonzie, force, fortbud, Freds342, Gaasb, GeorgieGirl, Geri, gerry capps, glcory, gljurczyk, goodneelix, Goomph, grantlee, grebe, Gregg Willow, Grey9712, GT MAN, hehbr, herk7769, HERmit, Himcules, hkreck, hockeytownmom, Horns07, Hostile2camp, iblanken, jamesmeece, Janet624, jbk, jdgris, jeeplj8, jerry226, jim44646, Jimmygee, JJvike, jkinger, jmarl1253, jmsokol, joenic53, joewbab, jonespkp, Jrljd, kb4srn, KMP44, ko777, Larman, larrys2112, latner, Lcountz, LKicklight, Lostincanada, lswartz, luv2drum, MACamper, Marc62, mcmilia, mctruck, mkrompeg, mmunn, MotocrossCamper, Mr.z, mrmurph, mtnguy, Oaklevel, OldCoot, OmegaQuest, pat319, patrapper, Pawpod, Peggy L., PeteG, Popcorn, Powerblast, QCCowboy, rappleby, Redheaded blue tick, RenoRock, ret2006, retiredguy, rhollar, rich30fqs, Rickwigg, Ripley711, RKC02, RoadDog66, rob and lisa, Robecage, rockport, RodeoGeorge, Rogers81, rotorhead1250, rschoono289, RubenZ, Rufinit, RVChick, rvroofer, rvsearcher, RWWNC, Sabdives, SabreDoc, Safirt, Scott1, Scotty2, Scratch, sfrye5853, sgbtgb, Shooter33, shurack24, sideout1961, snormr, SPBRBNJ, sponge, SPPD, sschifer, Stank Bait, Sun seeking, tandg98, Taylorgso, tclcyl, tetsurvivor, thehamguy1, Timtatioin, Tjburke7, tmmar, Tom and Kat, tomblakeney, Tomhusker, tomjsas, Trailblazer, travyp, tx_native, uncle46, VikingsFan, VinceU, vizsla owner, VTX Al, w9ila, wayne in florida, WEMig, whj77372, willieg, wmtire, WoodbneK, wplate, wyo700
Most users ever online was 1,401, 05-27-2013 at 08:56 PM.
Close [X]
