Old 07-27-2019, 03:37 PM   #1
Air Conditioning Vents
Our new 2019 Georgetown Series 5 is throwing out tons of debris from construction when we use the air conditioner. Please help
myaeger is offline   Reply With Quote
Old 07-27-2019, 03:46 PM   #2
Keep running it until it blows out all the debris and then clean up .
MR.M is offline   Reply With Quote
Old 07-27-2019, 10:26 PM   #3
Freetyme's Avatar
You mean the little foam BB like crumbs ? They'll
become less with use. Almost everywhere somthing is cut into the ceiling such as lights, vents, fans.
e
Freetyme is offline   Reply With Quote
Old 07-28-2019, 12:36 AM   #4
bikendan's Avatar
Yep, construction debris out of the a/c vents and clogging faucets, is very normal with new RVs.
Equalizer WDH
Old 08-02-2019, 02:21 AM   #5
CincyGus's Avatar
X2
Plug in at home and if you can run the AC a couple hours, going out and walking around in the camper every once in a while to make it flex and shift a little. I'm dealing with the same thing and it IS typical of a new RV.
Check your filter and your air vents for larger pieces that won't blow clear of the vents. Finding little bits of styrofoam, shavings of aluminum flexible duct, sawdust where they cut through the roof.
Be prepared for the same thing the first time you fire up the furnace also if they use different ducts along with the smell of the inside of the furnace burning off the coating. Takes 30 mins to a couple hours for that also.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
vent
