Old 08-27-2016, 04:18 PM   #1
Air return grille doesn't fit flush. Common?
Since the day we picked up our Cherokee the only thing that has bugged me has been that the air return grille doesn't fit quite right. I thought it was the filter, but even removing the filter it won't fit flush. It's bowed in the middle.
Is this common? If not does anyone have any suggestions? Here is a pic.
2017 Cherokee Grey Wolf Limited 26BH
kantonburg is offline   Reply With Quote
Old 08-27-2016, 04:36 PM   #2
If it were mine, I'd heat it up a little with a heat gun (hair dryer) and then bow and clamp it in the opposite direction and let it cool.
Old 08-27-2016, 04:48 PM   #3
Thanks OldCoot. I'll have to give that a try.
Old 08-29-2016, 07:25 AM   #4
Did it work?
GJCrawford is offline   Reply With Quote
Old 08-29-2016, 07:37 AM   #5
Originally Posted by GJCrawford View Post
Did it work?
I haven't tried yet. I had a work project I worked on about the whole weekend. Once the weather breaks this week I have a few other projects I'm going to do including that. I'll update when I do.
Sent from my SM-G900R7 using Tapatalk
Old 08-29-2016, 12:17 PM   #6
Ours has the same bow. I'll find some time to try the hair dryer trick ... hopefully soon.
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 08-29-2016, 12:30 PM   #7
danny4127's Avatar
same problem and i am on the second grill.Have to be very carefull when you remove to clean filter.
Danny and Beverly Plus Panhead (chiweenie)
2016 GREY WOLF 26RR LIMITED
2016 DOGE RAM 2500
2013 HARLEY TRI-GLIDE
danny4127 is offline   Reply With Quote
Old 08-29-2016, 12:39 PM   #8
Flybob's Avatar
While you are at it.
When I took my return vent cover off today to clean the filter, I also removed the ceiling plate to check that the return vents were sealed into the duct work. Good new it was. Upon putting it back together, I noticed that the 1 1/2 inch long sheet metal screws they used to hold the plastic ceiling unit to the AC frame stuck up an inch more than needed and were close to some of the AC wiring. I was concerned that while driving the wires could rub on the sharp screws and cause a short. For a simple fix, I cut 1" long pieces of small rubber hose ( 1/8" ID) and slid it over the protruding screws. Problem solved.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-29-2016, 01:50 PM   #9
ilmor's Avatar
If its on correctly, it shouldn't bow that much. You may also try buying another one. I recently did this because when I removed mine it got away from me, hit the floor just right and broke. They are cheap, Chinese plastic apparently.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-30-2016, 08:46 AM   #10
Wolverine 1945's Avatar
I think OldCoot has the right idea,,, but I might force the cooling with COLD water,,, so that it will set flat !!!
Wolverine 1945 is offline   Reply With Quote
