Old 10-10-2011, 08:01 AM   #1
RubenZ's Avatar
All in one LP/Gas/Carbon Monoxide Detector?
I'd like to replace the current detector in our RV with one that will detect all other gases. I'm not sure if ours is faulty, but I stored our Coleman Propane lantern in the storage area and it must have moved the knob and let the propane out and the entire RV smelled of it, but the detector never went off? I thought it was supposed to go off for situations like that? So I'm thinking maybe the one that came with RV is for different gases?
Anyways, is there a all in one that any one can recommend to replace factory one?
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 10-17-2011, 03:07 PM   #2
RubenZ's Avatar
No thoughts on this? anyone
Ruben Zamora
Old 10-17-2011, 03:17 PM   #3
MtnGuy's Avatar
The propane used in a Coleman lantern should activate the propane detector in your camper if there was enough concentration. If the gas slowly leaked out, then the concentration may not have been enough to set the detector off, meaning there was never enough concentration for the propane to ignite.
Try this: Light a butane lighter, blow out the flame but keep the button pushed down. Put that directly in front of the propane detector. The detector should go off within 30 seconds or so. If not, then it is probably time to replace the detector.
I see where you have a 2012 model, so it might be a warranty item.....many appliances carry a warranty longer than the camper warranty.
Old 10-17-2011, 03:24 PM   #4
I believe you require two different detectors as propane is heavier than air and thus should be mounted low and carbon monoxide being lighter than air is mounted higher.
This is the way it was explained to me.
riversedge is online now   Reply With Quote
Old 10-17-2011, 03:25 PM   #5
Triguy's Avatar
Ruben,
Would this be covered under warranty for you? I believe these have a 12-month warranty.
If DIY then I know that Safe-T-Alert has an all-in-one unit although I can't attest to its quality.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-17-2011, 03:31 PM   #6
Wanna Be Camper
SaskCampers's Avatar
Was the trailer battery connected? If not and you are not on shore power either the detector won't work.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-17-2011, 03:58 PM   #7
RubenZ's Avatar
Thanks guys. I'll have to check it out with that butane test. Do any of you know how long alarm sounds for? maybe it was sounding while we were out hiking.
Ruben Zamora
