Old 05-01-2012, 10:52 PM   #1
808
amp in shop
Hello I have a 396wp. There is an amp in the shop on the wall. I just had the trailler serviced and when I asked them why the amp did'nt make a difference on or off they told me it was for free standing speakers that go outside. I purchased this unit used and they said the previous owners must of kept the speakers. My question is if its for free standing speakers outside, where do i plug them in? Also when my trailler is pluged into the house, should the battery be charging?
808 is offline   Reply With Quote
Old 05-01-2012, 11:06 PM   #2
Can't help with the amp and speakers, but as for plugging in to the house, YES, your battery should be charging. If you are using a 30 amp to 15 (standard) house adapter, DO NOT try to run the Air Conditioner. The microwave might work, but the AAC will probably trip a breaker.
As for the speakers, plugs will be on the door side, so you can sit under the awning and listen to them, maybe?
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-02-2012, 10:43 AM   #3
808
Ok thanks for the info on the battery. As far as thehook up for speakers outside, there is two speakers built into the wall under the awning but i still have'nt found where you would connect two free standing speakers.
