Old 07-01-2014, 11:43 AM   #121
thestrangebrew's Avatar
Originally Posted by davemoore99 View Post
I trimmed one of mine yesterday with a band saw. It went better than I expected, I had to take about 3" off. Going to try them out for the first time this weekend!
I had to do the same with mine. Took off a good 3" and tried them out. Worked well on the asphalt, I'll be using them tomorrow for our maiden voyage.
Edit: I have a pair and only trimmed 1 of the levelers. Seemed to work well.
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is offline   Reply With Quote
Old 07-01-2014, 11:52 AM   #122
I trimmed the back edge on both so it doesn't make any difference which one goes where.
Old 07-01-2014, 11:56 AM   #123
indybp57's Avatar
This sounds like a stupid question, but did you trim the fat end or the tapered end? I cut about 1 1/2" off my tapered end and it still won't go under my tire because my new tapered end is too thick. So now I'm going to have to sand it down or cut it even shorter. I even cut the 45 degree corner off the thick end as Old Coot had suggested.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 07-01-2014, 12:01 PM   #124
I cut the tapered end about 3". YMMV.
Old 07-01-2014, 12:22 PM   #125
Hold them up like in the picture and then mark them with a Marks A Lot and then trim. I used the band saw first and then decided to take another 1/4" off on the table saw. I now have 1/4" of material from the 45 cut to the big round hole. Works a lot better. As I said before, I cut both.
Name:	Anderson Leveler corner.jpg
Old 07-02-2014, 02:22 PM   #126
Hadn't thought much about cutting both until OldCoot stated he did both. As I thought about it if I put the modified one under the front wheel and the unmodified one under the back one I worry that the front tire/axle will raise sooner than the back creating the tires to be uneven. Since the front one is no longer the 1/2 inch rise to start with. So I think I am going to go ahead and trim my second one as well today.
DHAJMoore
TT 2007 Forest River Shamrock 21RS
TV 2013 Ram 2500 5.7 Hemi Gas
davemoore99 is offline   Reply With Quote
Old 07-02-2014, 03:17 PM   #127
To clarify, I cut the 45 on both ramps, I did NOT cut anything off the front of either ramp, JUST the back corner of both ramps like the picture shows. I just went back and increased the 45 cuts to where there is 1/4" of material between the large hole and the 45 cut.
Name:	Anderson Leveler 45D cut.jpg
ID:	56957   Click image for larger version
Old 07-10-2014, 11:29 AM   #128
Trimmed Front one
Here is our setup with one of the levelers trimmed. I haven't decided if I need/want to trim the second one. I'd rather not if it's not necessary. I have to say they are awesome though!
DHAJMoore
Old 07-11-2014, 03:49 PM   #129
Finally got around to drilling a 1/2" hole the rest of the way thru the levelers and made a rope handle for them. Should be much easier to carry.
Old 07-13-2014, 02:40 PM   #130
dj3spots's Avatar
Very good idea!
dj3spots is offline   Reply With Quote
