Old 07-15-2013, 08:18 PM   #51
camper1999's Avatar
Originally Posted by JohnF View Post
Got mine today and they don't fit between the tires on my 21FBRS. I will likely cut the tip off one to see if it can work.
John
X2 but cut a quarter inch off and work great
2011 GMC 2500HD Diesel
Old 07-16-2013, 05:55 AM   #52
MtnGuy's Avatar
John
Let us know if that works.
Old 07-16-2013, 02:30 PM   #53
Did you try to put in flat on the ground between the tires?
You are supposed wedge it under one tire but have the other end angled up resting a little on the other tire. When you drive up on it....it drops down between them just fine. If your tires are close to 2" apart...then you might have to cut off a little on the tip.
jlwardn is offline   Reply With Quote
Old 07-18-2013, 10:41 AM   #54
2011 Forest River Stealth
rwtdct's Avatar
So, I went to the lake for a few days and was able to use mine, they worked fine. I did have to angle mine up between the tires. When I backed off of them I did have to get it just right to pull it out.
Here is a couple of pic's.
And a couple other pic's while there.
The decal on the back of my trailer
2011 Stealth CSFCK3214
2003 Ford F250 Crew Cab 4X4 7.3
2011 Polaris RZR 4
rwtdct is offline   Reply With Quote
Old 07-18-2013, 10:47 AM   #55
Originally Posted by jlwardn View Post
I know there is a guy in Cedar Springs that may take 2....
I will definitely take them, I'm leaving out of town tonight and will be back Sunday night late, but we could meet up somewhere early next week, if that works for you. I will PM you my number.
2014 Palomino Sabre 34-TBOK (picked up 5/11/13)
2008 GMC Sierra 2500HD Duramax
anthonyshaw is offline   Reply With Quote
Old 07-18-2013, 11:09 AM   #56
raspivey's Avatar
They do work...I bought, well it was an Andersen Rapid Jack..looks to be the same thing only bigger...from etrailer. It's got an 8" lift on it. with a big bubble level where you can see it from inside the truck, all you have to do is stick it behind the low side and back up until it's level. Chock everything and done. I think I'm done with blocks.
Old 07-18-2013, 11:16 AM   #57
From the pictures, it looks like they are barely wide enough for the tires?
I sure wouldn't want my tires hanging over the edge of these things for any length of time.
Why wouldn't they make them wider?
bakken is offline   Reply With Quote
Old 07-18-2013, 02:24 PM   #58
They are just about 5 inches wide.
Old 07-19-2013, 10:47 PM   #59
rwtdct's Avatar
I used mine to help a fellow RVer change a flat today. I had him back up on it rolling onto a little taller block. No jacks involved. He stated, " I am going to have to get a couple of them". Sorry, no pic's
2011 Polaris RZR 4
Old 07-23-2013, 04:04 PM   #60
Denver, CO
garbonz's Avatar
So Procedurally, you get to the site
get out of truck
put the 2 blocks in place.
get back in truck
back up till level ( or a little more to allow the wheel to equalize between the chock and the stop)
get back in truck and roll forward till stable
get out of truck
put in X-chocks or rotochoks or whatever.
unhook rig
TO REVERSE.
Get into truck
Hook up rig
back up a bit
get out of truck
pull front chocks
get back in truck
pull forward just enough to pull chocks
get out of truck
pull chocks
collapse.
To many steps.
I stick with the yellow jobs.
2017 Fuse 23T
