Old 07-01-2014, 11:43 AM   #121
thestrangebrew's Avatar
Originally Posted by davemoore99 View Post
I trimmed one of mine yesterday with a band saw. It went better than I expected, I had to take about 3" off. Going to try them out for the first time this weekend!
I had to do the same with mine. Took off a good 3" and tried them out. Worked well on the asphalt, I'll be using them tomorrow for our maiden voyage.
Edit: I have a pair and only trimmed 1 of the levelers. Seemed to work well.
2022 F250
2014 Rockwood Roo 233s
thestrangebrew is offline   Reply With Quote
Old 07-01-2014, 11:52 AM   #122
I trimmed the back edge on both so it doesn't make any difference which one goes where.
Old 07-01-2014, 11:56 AM   #123
indybp57's Avatar
This sounds like a stupid question, but did you trim the fat end or the tapered end? I cut about 1 1/2" off my tapered end and it still won't go under my tire because my new tapered end is too thick. So now I'm going to have to sand it down or cut it even shorter. I even cut the 45 degree corner off the thick end as Old Coot had suggested.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 07-01-2014, 12:01 PM   #124
I cut the tapered end about 3". YMMV.
2022 F250
Old 07-01-2014, 12:22 PM   #125
Hold them up like in the picture and then mark them with a Marks A Lot and then trim. I used the band saw first and then decided to take another 1/4" off on the table saw. I now have 1/4" of material from the 45° cut to the big round hole. Works a lot better. As I said before, I cut both.
Name:	Anderson Leveler corner.jpg
Old 07-02-2014, 02:22 PM   #126
Hadn't thought much about cutting both until OldCoot stated he did both. As I thought about it if I put the modified one under the front wheel and the unmodified one under the back one I worry that the front tire/axle will raise sooner than the back creating the tires to be uneven. Since the front one is no longer the 1/2 inch rise to start with. So I think I am going to go ahead and trim my second one as well today.
DHAJMoore
TT 2007 Forest River Shamrock 21RS
TV 2013 Ram 2500 5.7 Hemi Gas
davemoore99 is offline   Reply With Quote
Old 07-02-2014, 03:17 PM   #127
To clarify, I cut the 45° on both ramps, I did NOT cut anything off the front of either ramp, JUST the back corner of both ramps like the picture shows. I just went back and increased the 45° cuts to where there is 1/4" of material between the large hole and the 45° cut.
Name:	Anderson Leveler 45D cut.jpg
ID:	56957   Click image for larger version
Old 07-10-2014, 11:29 AM   #128
Trimmed Front one
Here is our setup with one of the levelers trimmed. I haven't decided if I need/want to trim the second one. I'd rather not if it's not necessary. I have to say they are awesome though!
DHAJMoore
Old 07-11-2014, 03:49 PM   #129
Finally got around to drilling a 1/2" hole the rest of the way thru the levelers and made a rope handle for them. Should be much easier to carry.
Old 07-13-2014, 02:40 PM   #130
dj3spots's Avatar
Very good idea!
dj3spots is offline   Reply With Quote
Old 07-13-2014, 03:58 PM   #131
The rope wasn't really my idea, someone on this tread suggested it and I had been thinking about some easy way of carrying the slick thing.s Finally just drilled them and made the rope loops. Sure made them easier to carry back to the truck.
I probably should have tied the wedges on one end of the rope and keep them together. May just do that.
Old 07-13-2014, 09:32 PM   #132
joforbess's Avatar
Hey oc. Did mine today. It does make it easy to carry.
2014 Salem 27RKSS - 2012 F150.
2012 Ford F150
2014 Salem 27RKSS
joforbess is offline   Reply With Quote
Old 07-13-2014, 09:42 PM   #133
I am changing mine, will take pictures tomorrow showing the results. Undoing the square knot and securing one end to the ramp and the other to the end of the wedge. Will be able to pull the rope and get the wedge out from under the ramp, drive off and pick up wedge and ramp together.
Old 07-13-2014, 09:44 PM   #134
Campin Cajun's Avatar
Just ordered 4 sets from etrailer. $39.99 a set
2013 Berkshire 390 BH
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 07-14-2014, 07:28 AM   #135
Got them changed so now I won't go off and leave the wedge.
Old 07-14-2014, 03:57 PM   #136
dj3spots's Avatar
Brilliant OC. I'm showing pix to my DH but he keeps saying send them to you to get the job done right! Lol
Old 07-14-2014, 04:03 PM   #137
BamaBob's Avatar
X2!!!
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-14-2014, 04:46 PM   #138
Send them, I still have a lot of rope left.
I doubt if I use them very much as when we go to FL, the sites have level concrete pads and patio, but they will be in the bed of the truck for possible use at Thousand Trails in Orlando. There, you never know.
Old 07-14-2014, 04:53 PM   #139
Professional Texan
TexasBob's Avatar
I bought two Anderson Levelers about a month ago. I was excited about giving them a try this past weekend. ...but the site was level.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 07-14-2014, 05:22 PM   #140
This is our setup,(Overpull up on one then place other behind) this works well for us Youroo!!
ID:	58197   Click image for larger version
