Old 06-12-2019, 07:23 PM   #1
Another battery
I was under my 2018 2861DS today and found another battery attached behind generator. Never knew it was there...anyone else?
Freelander is offline   Reply With Quote
Old 06-13-2019, 02:39 AM   #2
CincyGus's Avatar
Motorhomes usually have one for the vehicle, one or more for the camper (house battery).
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 06-13-2019, 06:33 AM   #3
Yes, I have one vehicle battery and two house batteries under the step, this is another one underneath mounted behind the generator.
Old 06-13-2019, 07:15 AM   #4
what type generator? i think some of the larger generators have their own starting battery. but i'm not sure about this.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 06-13-2019, 08:12 AM   #5
It's a Onan RV QG 4000, and I'm pretty sure it is a starting battery, it's just my Freelander did not have one. There is no mention of this anywhere, I just wanted other owners of this model and similar models to know about it if they didn't already.
Old 06-13-2019, 08:40 AM   #6
no that generator does not come with its own battery. you might trace the cables and see what they connect to: chassis or house. did you buy it new? does the dealer know?
Old 06-13-2019, 09:42 AM   #7
Normally they do not, I bought this new, I'll check with the dealer, I just wanted to let other 2861DS owners know. I haven't chased the wiring all the way, but it is mounted behind the gen., attached to it's frame and the wiring heads toward the gen.
Old 06-13-2019, 12:21 PM   #8
If it was a starting battery for the generator how does it get recharged? That generator does not have 12 volt recharging abilities. And if I was connected to the converter then it would also be connected to your two other house batteries. Is there a second converter / charger dedicated to charged this battery?
Old 06-13-2019, 12:43 PM   #9
Talked (emailed) with Jim Feece at FR, "The Chevy chassis comes with 2 batteries. This only used for the chassis." and it is in parallel with the main chassis battery.
battery
