Old 08-14-2016, 10:03 AM   #11
Thanks all ! Did all that was suggested except the cable from antenna. When we get back going up on roof to check it out. Thanks again!!
2015 Vengeance 25V
campingwithavengeance is offline   Reply With Quote
Old 08-14-2016, 10:25 AM   #12
NMWildcat's Avatar
Originally Posted by TimNJTA View Post
What kind of antennas did the people you ask use?
Side by side, my batwing style beats my buddies omni directional in reception.
Agreed! Our batwing was a great replacement for the OEM antenna and works better than most.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-14-2016, 10:26 AM   #13
Flybob's Avatar
If you have this one it is essentially junk. Te only thing it has in common with an RV antenna is it looks like one. You can replace it with a King Jack.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-14-2016, 11:26 AM   #14
bob213's Avatar
The new antennas FR is using are basically worthless. Only good thing is you don't have to worry about forgetting to crank it down. We have been to campgrounds where we got excellent reception with our last trailer that had the bat wing and can't receive anything with the new. The new digital signal is not as forgiving as the old analog signal. You almost have to be in direct line of sight to broadcast antenna to get good reception from the new round antenna. I have given up on that roof antenna. We either rely on park cable or bring our portable satellite setup.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 08-14-2016, 12:24 PM   #15
I have a 2015 335. The omni antenna is really a bad deal. ever FR has dropped them in favor of the Jack antenna and you can retrofit an omni with the Jack as long as you have access below for the knob.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 08-14-2016, 02:13 PM   #16
Same here, no reception with the new type antenna, instructions say once antenna head is installed on the pipe it cannot be removed. Has to be destroyed to take it off for access to roof antenna wire. Can anyone who has changed it out comfitm this
william brock is offline   Reply With Quote
Old 10-08-2016, 11:58 AM   #17
I'm up in afton ny speedway all other campers want to no why I have tv and they don't mine might go out a sec or two but they all have new type and nothing. I also put on batwing extender 😄
retired on a mountain is offline   Reply With Quote
Old 10-08-2016, 12:29 PM   #18
I would like to know as well.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
antenna
