08-13-2016, 01:41 PM
Antenna
Ok the last 2 camping trips we have been on , we are unable to get tv reception. The last place had cable and we were able to get that working but very limited on channels.
Our antenna is NOT the one you raise from inside, it is round flying saucer looking thing.
Not sure what is going on with it, really not that experienced with the tv, however our last trip and right now we are dealing with terrible weather.
Asked the camping neighbors ,all have tv with no reception problems
I have pushed on and off cable button on input ,tried to reset both ways. Retightened all the cables to tv and inputs
Any body have any other ideas??
08-13-2016, 07:18 PM
King of the Road
If everybody has the same problem perhaps there's no TV reception in that area?
Sent from my LG-H830 using Tapatalk
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
08-13-2016, 07:40 PM
Might have to check connections at antenna and internal also. Check for connections/splitters in cubbies and behind the cable wall outlets. You can also connect a cable directly to the antenna and run it in a window to your TV to ensure its actually working although it might be a weak signal without the power boost (switch with green light). Also make sure your TV is set to antenna and not cable. Good luck!!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
08-13-2016, 08:01 PM
You misread. OP said, "Asked the camping neighbors ,all have tv with no reception problems ".
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
08-13-2016, 08:30 PM
Left Coast
Has it ever worked?.... No pic or fuzzy pic?
08-13-2016, 08:34 PM
King of the Road
Ooops, my Lyxdexia again.
2016 Crusader Lite
Single slide
08-13-2016, 08:50 PM
Yup. Been that, done there.
2018:16
Total 239
08-13-2016, 08:55 PM
did you a auto scan for the channels in that area, when we use the ant or cable here at home I have to auto scan the channels from our last trip, ie Gulf Shores
08-13-2016, 08:59 PM
Did you turn on the antenna booster?
08-14-2016, 09:59 AM
What kind of antennas did the people you ask use?
Side by side, my batwing style beats my buddies omni directional in reception.
Like said, make sure your coax connections are tight and correct, and the booster wall plate button is pressed with the green light on. Set tv for air, auto scan and hope for the best.
Also, make sure the booster is off when using park cable.
2017 Freedom Express 271bl
2013 Silverado Z71
08-14-2016, 10:03 AM
Thanks all ! Did all that was suggested except the cable from antenna. When we get back going up on roof to check it out. Thanks again!!
2015 Vengeance 25V
08-14-2016, 10:25 AM
Agreed! Our batwing was a great replacement for the OEM antenna and works better than most.
08-14-2016, 10:26 AM
If you have this one it is essentially junk. Te only thing it has in common with an RV antenna is it looks like one. You can replace it with a King Jack.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-14-2016, 11:26 AM
The new antennas FR is using are basically worthless. Only good thing is you don't have to worry about forgetting to crank it down. We have been to campgrounds where we got excellent reception with our last trailer that had the bat wing and can't receive anything with the new. The new digital signal is not as forgiving as the old analog signal. You almost have to be in direct line of sight to broadcast antenna to get good reception from the new round antenna. I have given up on that roof antenna. We either rely on park cable or bring our portable satellite setup.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
08-14-2016, 12:24 PM
I have a 2015 335. The omni antenna is really a bad deal. ever FR has dropped them in favor of the Jack antenna and you can retrofit an omni with the Jack as long as you have access below for the knob.
2015 335DS
08-14-2016, 02:13 PM
Same here, no reception with the new type antenna, instructions say once antenna head is installed on the pipe it cannot be removed. Has to be destroyed to take it off for access to roof antenna wire. Can anyone who has changed it out comfitm this
10-08-2016, 11:58 AM
I'm up in afton ny speedway all other campers want to no why I have tv and they don't mine might go out a sec or two but they all have new type and nothing. I also put on batwing extender 😄
10-08-2016, 12:29 PM
I would like to know as well.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
