Old 08-13-2016, 02:41 PM   #1
Antenna
Ok the last 2 camping trips we have been on , we are unable to get tv reception. The last place had cable and we were able to get that working but very limited on channels.
Our antenna is NOT the one you raise from inside, it is round flying saucer looking thing.
Not sure what is going on with it, really not that experienced with the tv, however our last trip and right now we are dealing with terrible weather.
Asked the camping neighbors ,all have tv with no reception problems
I have pushed on and off cable button on input ,tried to reset both ways. Retightened all the cables to tv and inputs
Any body have any other ideas??
campingwithavengeance is offline   Reply With Quote
Old 08-13-2016, 08:18 PM   #2
King of the Road
If everybody has the same problem perhaps there's no TV reception in that area?
Sent from my LG-H830 using Tapatalk
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
Dano1955 is offline   Reply With Quote
Old 08-13-2016, 08:40 PM   #3
NMWildcat's Avatar
Might have to check connections at antenna and internal also. Check for connections/splitters in cubbies and behind the cable wall outlets. You can also connect a cable directly to the antenna and run it in a window to your TV to ensure its actually working although it might be a weak signal without the power boost (switch with green light). Also make sure your TV is set to antenna and not cable. Good luck!!
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-13-2016, 09:01 PM   #4
Evereddie's Avatar
You misread. OP said, "Asked the camping neighbors ,all have tv with no reception problems ".
There are 10 types of people in the world.
Those that know binary, and those that don't.
Evereddie is online now   Reply With Quote
Old 08-13-2016, 09:30 PM   #5
Left Coast
Has it ever worked?.... No pic or fuzzy pic?
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
Old 08-13-2016, 09:34 PM   #6
King of the Road
Ooops, my Lyxdexia again.
2016 Crusader Lite
Single slide
Old 08-13-2016, 09:50 PM   #7
Evereddie's Avatar
Yup. Been that, done there.
Old 08-13-2016, 09:55 PM   #8
No-Fish's Avatar
did you a auto scan for the channels in that area, when we use the ant or cable here at home I have to auto scan the channels from our last trip, ie Gulf Shores
No-Fish is offline   Reply With Quote
Old 08-13-2016, 09:59 PM   #9
Moderators' Assistant
bikendan's Avatar
Did you turn on the antenna booster?
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 08-14-2016, 10:59 AM   #10
What kind of antennas did the people you ask use?
Side by side, my batwing style beats my buddies omni directional in reception.
Like said, make sure your coax connections are tight and correct, and the booster wall plate button is pressed with the green light on. Set tv for air, auto scan and hope for the best.
Also, make sure the booster is off when using park cable.
2017 Freedom Express 271bl
2013 Silverado Z71
TimNJTA is offline   Reply With Quote
antenna
