Old 05-13-2010, 06:47 PM   #1
Antenna leaks
Greetings, anyone out there have advice on how to stop a "slightly leaking down the middle of the inside of the rotation disc" leak?? The dealer wants to replace the entire antenna from the base (even though it's not leaking at the base!!) Its been my experience that there is a "worm gear kit" with seals and such that manage water issues from Winegard
cthelite is offline   Reply With Quote
Old 05-13-2010, 07:44 PM   #2
yes just put new o-rings in simple job
skywagon is offline   Reply With Quote
Old 05-13-2010, 07:52 PM   #3
Thanks, I'll definitely try that first
Old 05-14-2010, 09:07 AM   #4
Check the rubber boot for the cable on top of roof. I had a 5th wheel that the boot would work its way off and leak on the bed.
ArkyGeorgetown330TS is offline   Reply With Quote
Old 05-14-2010, 09:54 AM   #5
Campfire Master
Thats exactly what happened to mine. I put some silicone in the boot and pushed it back on. Been fine ever since.
AVid is offline   Reply With Quote
Old 05-14-2010, 10:15 AM   #6
MtnGuy's Avatar
The worm gear kit is probably what you need. I comes with new washers and the O-Ring.
Check Package #7 (RP-4000) at the bottom of the page out: http://www.winegard.com/kbase/upload/2452013.pdf
Old 05-14-2010, 10:41 AM   #7
MtnGuy's Avatar
Here is about the cheapest I could find that part on the net: Swiden Distributing Inc - Worm Gear, Elevating Shaft Assembly: RP4000
Old 05-14-2010, 05:11 PM   #8
thanks you guys are the best!! This site ROCKS!!
Old 05-14-2010, 05:14 PM   #9
Thanks for the feedback. WILL-DO
Old 05-14-2010, 05:15 PM   #10
Thanks TONS! I will check this
antenna
