Old 07-22-2011, 07:52 PM   #1
Antenna won't turn
We bought our camper in February and do not have a TV. Yesterday I decided to exercise the TV antenna since we have not used it at all. I was able to raise the antenna with no problem. I pulled down on the "wheel" and tried to turn it, but it would NOT turn. I didn't want to force anything, but it would not turn. Am I missing something. The dealer did show us how it worked, but it has been a few months...
Thanks,
Chuck
2016 Puma 30RLIS
2011 Catalina 19RD - totalled by hail
cbenslay is offline   Reply With Quote
Old 07-22-2011, 08:27 PM   #2
Freds342's Avatar
There's a little plug that you can remove and squirt silicone oil into part of the mechanism, and you should 'wash down' the exposed worm gear with silicone oil.
The area under the skirt around the edges should also be liberally sprayed with the same.
A common problem is that, during installation, some of the Dicor sealant gets between the stator and rotor on the antenna. Check for that, and also, squirt liberal amounts of silicone lubricant under the skirt of the rotating joint.
Oughta do it!.
BTW: Don't use WD-40, or any other petro-based lubes on a membrane roof! (And clean up the residual silicone with a paper towel. There should be lots of residual, if you do it right!!!)
Then raise the antenna and rock it back and forth until it loosens up. There are a lot of aluminum parts touching each other in there, and they need to be un-married.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 07-22-2011, 08:43 PM   #3
sherdep's Avatar
kinda like stated above - go on the roof and check it out after you raise the antenna - had seen a few posts about silicone in the mechanism keeping it from turning so might be worth a shot to look at that as well.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 07-23-2011, 06:47 AM   #4
MtnGuy's Avatar
Be careful removing the worm gear nut. Be sure the antennae raising mechanism is not under pressure. I found this out the hard way.
For a camper that was bought in February, and maybe being unfamiliar with the inner workings of the antennae lift system, I think I would have someone on the inside pull down the locking ring, and someone on the roof "gently" turn the antennae until it frees up.
Here is a diagram of the Sensara, and also "vague" directions on how to lubricate the 0-rings: http://www.winegard.com/kbase/upload/2452013.pdf
Old 07-23-2011, 08:35 AM   #5
jimh's Avatar
did u try turning it in both directions? it has a stop in it when the arrows line up.
i don't know how much force u used but it does take a little effort to move it.
jimh is offline   Reply With Quote
Old 07-23-2011, 10:55 AM   #6
Big Dawg's Avatar
Mine was brand new, and would not turn, when I inspected it, it had sealant around it and was causing it not to move. I just removed a little from where it turns and it works perfect.
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
Old 07-23-2011, 01:56 PM   #7
Terier's Avatar
There was a learning curve for me to learn on how much force is needed to move it. Now that I have done it a couple of times it does get a bit easier.
I was afraid of breaking it but when my s-i-l showed me on her 5th wheel I could see that it does take a bit of work.
You could always check another tt on the dealer's lot and see how easy or not it turns.
Old 07-23-2011, 08:28 PM   #8
Freds342's Avatar
The "Little Plug" is a plastic plug, about 1/4" o.d. that pops off the top of the unit to accept lubricant. Not the big nut over the worm gear.
Sorry if I was vague. I'm kinda known for that when my brain is outrunning my fingers.
Old 07-25-2011, 12:10 PM   #9
Thanks!
Thanks for all of the replies! I did try and move it in both directions without any luck. I tried to turn it as hard as I dared, but was afraid of breaking something. I will climb up on the roof and have my wife stay inside the camper. Hopefully between the two of us and some silicone spray we can get it moving!
Chuck
2016 Puma 30RLIS
antenna
