10-28-2017, 10:24 AM
#21
Sunseeker 2500TS,,, 2 gallons is what I use after blowing sys out completely !!!
A little over 1 & a half gallons in the FW tank,,, left over goes in the drains & Toilet !!!
10-28-2017, 12:08 PM
#22
RetiredRVer
Originally Posted by markb422
Most newer RV's have water less traps and do not require antifreeze.
As far as adding to holding tanks, I usually get enough down the drain when filling the system waiting for the pink stuff to come out. That is if you blow out the water first and drain the tanks completely.
I just did my MH with one gallon of antifreeze.
Waterless traps? Please explain!
Joe & Sandy
Mentor, Ohio
2017 Ram Laramie Longhorn Crew Cab 4X4 Cummins Diesel
2017 Coachman Chaparral 336TSIK Fifth Wheel
2018 AT 18 Alaska group
10-28-2017, 01:25 PM
#23
X2! How would you keep sewer smell out of the RV. Just trying to learn!
10-28-2017, 08:56 PM
#24
Why not replacing the filter housing by a short pipe with fittings. Having a filter out of the RV permit to leak on the ground rather than in the rig.
Keep away of eventual problem.
10-29-2017, 02:00 AM
#25
http://hepvo.com/ is the name of the trap replacement.
10-29-2017, 06:19 AM
#26
That's the plan. I didn't have time find or make a solution this fall though.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
10-29-2017, 08:08 AM
#27
Originally Posted by dbledan
I think I would rather have good old P traps !!!
With the hepvo I see many possible problems !!!
10-29-2017, 03:12 PM
#28
I am not selling them. Never seen them. Just answering questions.
11-03-2017, 08:17 PM
#29
I do not run antifreeze thru the water lines. I blow them out, have been doing this method for over 10 years. I then pour antifreeze in the traps, toilet and some into the tanks. I leave my tank valves open so putting a lot in the tank will just run out. Have never had a problem with any freezing.
11-04-2017, 09:06 AM
#30
Left my tank valves open once for a couple of days,,, went out to find drain lines full of Maggots !!!
11-04-2017, 09:42 AM
#31
Kasual Kamper
Yeah, not a great idea. :thumbsdown:
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
11-04-2017, 09:52 AM
#32
I don't recommend leaving the dump valves open. But if you do someone recently posted a vented cap that would solve the critter issue.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
11-04-2017, 11:21 AM
#33
Just as confused as you
How do these work with hair? DW has shoulder length hair and every so often I have to clean the clumps out of the shower drain at both the house and TT. I would think the hair would block them open.
Richard & Jill
11-04-2017, 06:59 PM
#34
Waterless traps are fairly new to the rv world I believe. They are basically a duck bill check valve. Opens as water passes through, in one direction only, then closes to prevent back flow or gases. used for a long time in other applications. To me, I think they would be trouble free if installed in the vertical but in the horizontal, we will see. Have three in our MH. Two horizontal and one vertical.
11-05-2017, 09:01 AM
#35
There probably used because they are probably cheaper than using a P trap ???
Good Luck !!!
11-05-2017, 02:21 PM
#36
Regarding leaving tank valves open. After everything is completely drained the cap is reinstalled. No critter or maggot problem.
11-05-2017, 07:14 PM
#37
Originally Posted by w021095
I usually use three to four gallons, depends on the trailer. RV antifreeze is cheaper than fixing a broken water line or valve. Blow out the system through the low point drains, remove the anode rod in the water heater, (I put a piece of stainless steel screen in the hole for the anode rod, to keep out the critters)
What’s the reasoning for leaving the anode rod out for winter if the tank was drained? I put mine back in thinking it was ready to go for spring.
2017 Micro Lite 21DS
2018 Ford Expedition
11-05-2017, 07:25 PM
#38
I put mine back in to keep critters out of the tank.
I found a grasshopper in my shower drain from our last campout. He hitched a ride on a bucket I keep in there for travel. Went to the drain looking for water and a way out I guess. I am thinking I will leave him there until DW sees him and screams for me to remove him.
11-05-2017, 08:01 PM
#39
They remind me of the dust boots on diesel farm tractors air filters. Out in the dusty fields they would get packed with fibers from corn stalks and they would stay slightly open until you pulled them off and cleaned them good.
Richard & Jill
11-05-2017, 08:09 PM
#40
Just a habit, I open the water heater bypass to make sure antifreeze flows through all of the lines and flows out the water heater, have used the same piece of stainless screen on three campers for the last fifteen years.
2022 Rockwood 8328BS
2019 Ford F150 Ecoboost Super Crew
