Old 06-22-2018, 07:25 AM   #1
Teamgreen's Avatar
Any way to get a better Tv signal?
Hello:
Been a member since buying a 2017 Forest River Grey Wolf 23MK Last year.We frequently go to a campground in the Northeast which has no cable.
We usually can pick up a few public service channels and a few more local ones with our hotspot in our Chevy Silverado. Hard to do as you have to keep the key on all the time for it to work and our plan had only 10 gigs of data.
How much do we have to spend to get more channels?
PS. The campground has a lot of trees and is far away form any large city.
Thanks for the great site!
Teamgreen is offline   Reply With Quote
Old 06-22-2018, 07:40 AM   #2
Dish or Directv is the only way to go. We got it for home and a extra box for our seasonal site and it works great. You need clear line of site to SE.
Twincamper is offline   Reply With Quote
Old 06-22-2018, 08:21 AM   #3
Kaadk's Avatar
Assuming you already know about the antenna booster, and that it's on, the only other thing you can do is with the antenna itself. A directional antenna (turned in the right direction) will typically provide better gain than an omni-directional, so first, what kind of antenna is on your rig?
Secondly, have you used one of those antenna tower mapping websites to see what should be available in your area? There's a variety of them out there like this one:
TV Station Locator Tool - Over The Air Digital TV
You'll want to make sure there actually are signals to pick up before you go too extreme in your modifications.
Lastly, if there are signals, and you do have the antenna pointed at them, the last measure would be to try to get it over the tree-line, or at least higher than it is now. That's going to take an external antenna, some kind of antenna mast, a way to have the mast raised (I've seem some strapped to rear ladders, some u-bolted to the side of rigs, etc...) ways to run the cabling, power lines for the booster.... I.e. All doable, but enough of a hassle that I really hope you don't have to resort to those measures.
Alternatively, our solution to lack of TV signal is this:
https://www.apple.com/ca/shop/produc...tal-av-adapter
We typically have a bunch of movies downloaded to the tablet or my phone, or one of the kid's tablets so if we really get stuck, we've got plenty to watch.
Old 06-22-2018, 09:20 AM   #4
Usually Confused Member
emm-dee's Avatar
If your Silverado is 2015 or later you can get the AT&T Connected Car plan for $20 a month...unlimited data subject to “management” after 22 gig. The management thing is based on tower congestion so it’s pretty rare outside big cities. I’ve used over 800 gig this month (that’s gigs, not megs) with no “management”. The bad thing is you do have to leave the truck radio powered.
As far as entertainment if you get DirectTV Now for $35 a month and stream it on ANY AT&T plan there’s now charge against your data.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 06-22-2018, 09:26 AM   #5
Slightly off topic...
emm-dee could you point me to something that says this in writing?
I have ATT & DirecTV Now and my local rep says the data WILL be charged against my current plan. (not unlimited)
They tell me the only two plans it wouldn't be charged against is the AT&T Unlimited Plus Enhanced℠ and the AT&T Unlimited Choice Enhanced℠.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 06-22-2018, 10:29 AM   #6
emm-dee's Avatar
I should have said AT&T device, not plan. However, the info given by your local rep is incomplete. I have the Family Share plan with 20 gig shared data. We have five iPhones and one iPad on the plan ($170 per month) and have never gone over 15 gig usage. That plan is not unlimited data. It’s hard capped at 20 gig (plus rollover amount) and has a hefty charge for any overage. But we use the DirectTV Now app on all the phones and have never been charged.
I also understand the free DTV data is available on the prepaid devices (used to be called GoPhones).
https://www.att.com/esupport/article...less/KM1248135
Curious if the local rep who gave you the info was ATT or contract. The ATT stores you can walk into usually have the most accurate information but it has to be an ATT company owned location, NOT a reseller. Resellers are notorious for giving bad info in order to “upsell” your plan and make more commissions.
Old 06-22-2018, 10:53 AM   #7
Just as confused as you
Scrapper's Avatar
I agree with higher is better, I'm 50 miles as the bird flies from the nearest OTA tv stations. Being surrounded by trees and raising my antenna 5 feet higher made a huge difference in reception.
Richard & Jill
Camping since 1989, seasonal since 2000
Car Shredder Operator/Technician, Scrap Metal Recycling - retired
Scrapper is online now   Reply With Quote
Old 06-22-2018, 10:54 AM   #8
BandJCarm's Avatar
Just understand that many of the suggestions require a WiFi signal to implement.
Without that, either OTA signal OR a portable dish is required for tv viewing.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 06-22-2018, 11:14 AM   #9
Originally Posted by Teamgreen View Post
.... How much do we have to spend to get more channels?
not much if you're talking about Over The Air channels, ... our original tv antenna has never been worth a hoot, ... a couple of months ago a camper at the site beside us had an inexpensive aftermarket OTA antenna from Walmart(link below) mounted on a painters poll from Lowes(link below), ... I copied his setup and we're amazed at the improvement over the FR antenna, ... at that cg we had only been able to pick up 4 very weak channels, now we get 28 strong reliable channels, ... if you're talking about cable channels, that's a whole different ballgame, ...
https://www.walmart.com/ip/Onn-by-Wa...range/56136521
https://www.lowes.com/pd/Mr-LongArm-...n-Pole/4755038
ID:	176841   Click image for larger version
ID:	176842   Click image for larger version
ID:	176843   Click image for larger version
fella10 is offline   Reply With Quote
Old 06-22-2018, 11:23 AM   #10
glsimms's Avatar
fella..... I like your idea! Plus it's a very affordable mod!
Question: How do you run your coax cable?
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
