Old 12-20-2010, 07:18 PM   #21
Toy-aholic
I can atest for the TST system (Truck System Technologies) as being a great system....I installed a set this summer after have a tire shredding that I was alerted to by a passing motorist. After installed, I'm very pleased with it's performance. The readout screen has a rechargable internal battery that once charged...you can put the cord away for the summer! Readout shows pressure & temp. And sensor batteries are replaceable.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 12-21-2010, 10:26 PM   #22
Infractee
Originally Posted by youroo View Post
Yes,they (The 4 tpms units FAILED) that were instaled inside of the 4 tires,just like the factory ones from GM,Ford,Honda! Went to a lot of work to install instead of screw on valve stem type. The distributor would not replace or repair them.They (TPMS) units only worked (2) weeks. If I didnt explain it to your satisfaction ask your teenage daughter!! Youroo!!
Yes, excellent explanation. Thanks?
RhoZeta is offline   Reply With Quote
