Old 03-20-2012, 11:09 AM   #1
Anyone install a 30 amp Marinco inlet fitting?
I've been pondering installation of a Marinco cord inlet to make the 30 amp cord detachable. I read on the ModmyRV site that you can remove your old "pull-through" cord hatch (mouse hole) and install a round inlet right in the same opening as the old hatch. And it says you can even use the same mounting holes.
But.... Our hatch is 5" in diameter and the Marinco inlet is under 4". What would I do? Leave the old cord hatch in place and install the new inlet elsewhere? Cut out the center part of the existing hatch and try and mount the new inlet into the old hatch? Or, if the old opening happens to be small enough, use that and caulk the old screw holes?
The Marinco site seems to show another ring in the conversion kit that mounts behind the contoured inlet which makes it wider overall, but there is no mention of it or a part number. It just seems to show up in one photo. Is that extra ring what I need I wonder?
Kinda confused here as I'm not sure if we have a non-standard cord hatch or if ModmyRV is incorrect. Anyone know what the right approach is?
ps: The cord storage area is under/behind a dinette seat. The cavity had no access to it in case the cord got tangled up. So I removed the 5/8" plywood top (accessible from inside the rear storage compartment) and put in a removeable cover. There's a ton of space in the cavity so if I put in a detachable cord inlet, there'll be more storage space available in the TT, albeit not the easiest to get to.
myredracer is offline   Reply With Quote
Old 03-20-2012, 11:57 AM   #2
TURBS's Avatar
links ? pictures ?
Old 03-20-2012, 01:54 PM   #3
ddemme's Avatar
Marinco makes a kit that includes a trim ring, gasket, box, and everything: Marinco 55-8880 Maro 30A RV Detachable Power Conversion Kit
This was going to be my next mod if we'd kept the popup. Fortunately, the Roo came the the detachable plug.
Drew & Kendra
Lucky & Bentley the camping dogs
2011 Ford F-150 SuperCrew EcoBoost w/tow pkg.
2012 Rockwood Roo 23SS
ddemme is offline   Reply With Quote
Old 03-20-2012, 01:57 PM   #4
camper_Lucy's Avatar
I think you would need to install a support/cover that you could then use to drill a reduced size hole. Marinco inlets are made to fit into either a 2&3/4 or 2&7/8 hole depending on which model you chose.
http://www.marinco.com/files/support...als/100697.pdf
Even with the conversion kit you still have the same hole issue, here are the install instructions. a 5" hole will be to big the kit fits into a 2 & 3/4 hole.
http://www.marinco.com/files/support...als/200781.pdf
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 03-20-2012, 02:11 PM   #5
TURBS's Avatar
Just a random thought but why change it?
Old 03-20-2012, 03:31 PM   #6
ddemme's Avatar
If you have the standard mouse hole, you need the 30ARVKIT from Marinco and you'll want to follow installation type B from the manual: http://www.marinco.com/files/support...als/200781.pdf
Some reasons to do the conversion are that it frees up storage space in the camper and you can secure the cord when not in use. Thieves have been known to go through storage lots and steal the cords. It only takes 2 seconds to pull a cord out of the mouse hole and lop it off and I guess there's a lot of copper in those 30 amp cords.
Drew & Kendra
Old 03-20-2012, 03:55 PM   #7
My old trailer had the pull-out cord, the new one has the detachable one. Preferred the pull out one. As I was typing this, read your reply directly above. How do you plan on securing the cord when not in use? Just about all storage compartments can be unlocked with the same key. Wayne
wayne anthony is offline   Reply With Quote
Old 03-20-2012, 04:05 PM   #8
I would trade my detachable cord for the permanant one in a second. One of these days I'm going to see if there is room to do such.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 03-20-2012, 04:08 PM   #9
TURBS's Avatar
Which is why I asked why would you change it!
Besides either way you still are storing the cord
Old 03-20-2012, 05:07 PM   #10
ddemme's Avatar
The main reason I wanted to do this on our popup was space. The cord storage took up half of the rear dinette bench which could have been better utilized. A neatly wrapped 25' cord takes up much less space than that. Had I done it, it would've been stored in my 'power' rubbermaid container which used to live in the front bin of the popup.
As far as the security part goes, its not an issue for us. We're fortunate to have a yard big enough to keep our camper in. You're mostly right about the key, but I think that FR is changing it up a little more these days. However, I don't think we're talking about some kind of organized crime syndicate that has access to RV keys and a detailed plan for the heist.
Having a detachable cord that can be neatly stored in a minimum amount of space either inside the coach or in a locked storage compartment is by no means foolproof, but its better than nothing.
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." -Douglas Adams
Drew & Kendra
