Old 10-29-2011, 12:45 PM   #1
frankm's Avatar
Anything wrong with this picture?
At a CG near Ft. Myers, Fl this weekend and this is the AC pedestal. I'm connected to the 30amp side w/surge protector.
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 10-29-2011, 01:14 PM   #2
Yes, 50AMP is not 220V.
Len & Cheri is offline   Reply With Quote
Old 10-29-2011, 01:39 PM   #3
sherdep's Avatar
DOH - hopefully it was just mis-labeled or whom ever unsuspecting plugs in will be in for a hot mess
if you have a checker for 50 amp I would to see if not advise the campground to keep another RV'er safe
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 10-29-2011, 02:10 PM   #4
realebill's Avatar
its correct...see the link---gives a detailed explanation of this type of 50amp,220vt. service
The 50-amp 120/240-volt 3 pole 4
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 10-29-2011, 02:55 PM   #5
This is the best explanation I have seen on this topic! So many do not comprehend this concept of electric very well!
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
https://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 10-29-2011, 04:54 PM   #6
sherdep's Avatar
I always thought the 50 amp circuit was just a 110 leg with a 50 amp breaker
it uses two 110 legs which essentially is 220 but it just seperates them in the camper - am I reading this correct?
Old 10-29-2011, 05:38 PM   #7
realebill's Avatar
50amp
correct. just like the L1430 plug on a generator. most midsize generators put out 30amp-220vt, but you can get a cord to plug into the 30 amp socket which splits into 4-110vt receptacles. a higher end RV which has a 50amp input will split the current into 110vt circuits internally,
an RV which has a 30amp feed has a cord that WILL NOT FIT in a 50 amp receptacle,so you cannot plug into it by mistake.
Old 10-29-2011, 05:46 PM   #8
fast murray's Avatar
It should be labeled 120/240V 50A. What they have there isn't necessarily wrong, it's just old school. Your right in that it is 2 120V phases with a separate grounded(neutral) and a grounding conductor. The 120V phases are not the same though and going between the 2 of them gives the 240V potential with 120V to ground.
fast murray is offline   Reply With Quote
Old 10-29-2011, 06:12 PM   #9
Lottery Non-Winner
Ovair's Avatar
Nice link. I've tried to explain that before and I will use the link next time it comes up.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 10-29-2011, 07:40 PM   #10
Hoo Dad's Avatar
I was going to say what's wrong with this picture is that I'm not there
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 10-29-2011, 09:16 PM   #11
Here is another great write up about 120/240 and how adaptors are wired.
Electrical Adapters
~Andrew
https://rvpdi.com
Old 10-30-2011, 05:35 AM   #12
What campground are you at? We're heading to San Carlos Veteraans Day weekend
Fourn3833 is offline   Reply With Quote
Old 10-30-2011, 07:50 AM   #13
frankm's Avatar
You are correct, we (I) have been drilled to think of my 30amp TT, even 50amp rigs, as 120v only and not for a second to think of think of it as 240v. So when I saw the 220v label it freaked me out a little.
All is well, I talked to the park attendant and it had already been brought to his attention. He's unsure what he's going to do.
Can't blame you! Friday rained all day but yesterday and today is just beautiful! The park's name is W.P. Franklin North, part of Lake Okeechobee waterway system, and it is managed by the Army Corps. Facility Details - Recreation.gov, W.P. Franklin N (FL) - Recreation.gov
Frank & Rita M
Old 10-30-2011, 01:10 PM   #14
Hmm...so if you use an adapter that allows you to plug your 30AMP TT plug into a 50A outlet post is one leg on the adapter dead so you don't get both 110V lines going into the TT?
Old 10-31-2011, 05:57 AM   #15
Bump
Old 10-31-2011, 06:46 AM   #16
You are correct. If you use a 30 amp to 50 amp adapter, you're inly using one leg of the 50 amp receptacle. The other leg isn't hooked up.
Gotta go campin!
Old 10-31-2011, 06:51 AM   #17
Thanks!
Old 10-31-2011, 07:53 AM   #18
realebill's Avatar
50 to 30 dog bone adapter
that's correct..see the previous post by Acableguy showing a diagram of a 50 to 30 amp dogbone adapter.
Old 10-31-2011, 09:36 AM   #19
acadianbob's Avatar
Great stuff you guys! I just learned a lot!
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 10-31-2011, 10:10 AM   #20
frankm's Avatar
x2!!
Frank & Rita M
