Old 07-25-2011, 07:22 PM   #1
are jacks stablizer or level jacks
when you use the jacks on min lite lets say the 2104 are they just for stalbilaztion of trailer ? or are they are also used to level the trailer
skypilot5300 is offline   Reply With Quote
Old 07-25-2011, 07:30 PM   #2
grhodes50's Avatar
I don't know exactly what jacks are on your trailer, but if they're like most they are for stabilizing only.
Gary & Trish
2018 Nights Camped - 5
Old 07-25-2011, 08:30 PM   #3
bikendan's Avatar
Stabilizers!! don't use them for leveling or you'll be replacing them or having your frame re-straightened.
Old 07-26-2011, 12:04 AM   #4
Most of the screw type scissor jacks will support 5000 pounds, and I have a pair I use in the garage to pick up cars, and use for jack stands. The one leg style are just stabilizers. As for leveling, depends on your frame, length of the trailer, etc. Some longer lightweight trailers you may warp the frame, or twist it, so the story goes, by using the corner jacks to level. I have used mine, scissor style, to level the last inch or so. Your mileage may vary.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 07-26-2011, 01:16 AM   #5
bikendan's Avatar
even the scissors type are not for leveling, but for stabilizing.
doesn't matter how much they can support if they tweak the Mini-Lite's frame.
Old 07-26-2011, 09:54 AM   #6
I included this warning in post #4
"Some longer lightweight trailers you may warp the frame, or twist it, so the story goes, by using the corner jacks to level"
LadyWindrider
