Old 03-04-2016, 12:05 PM   #21
Dr Travel
We've got about 8500 miles on our Westlakes, little sign of wear and running fine. We seldom go over 60, max speed ever is 65. Its okay for folks to pass us, we are not in a hurry.
robsshots is offline   Reply With Quote
Old 03-04-2016, 12:28 PM   #22
21 FBRS 97 nights camped
wnelsonfl's Avatar
I have at least 23,000 on my Westlake tires. Age and weight are issues but they seem fine on my 30 month old 21ft FRBS FLAGSTAFF.
Only problem an occasional nail or screw.
wnelsonfl is offline   Reply With Quote
Old 03-04-2016, 12:37 PM   #23
The OP has about 8000-10,000 miles on them and they look like new. So we're debating if they're any good? Hmmm.
Our W&P had Westake E rated tires. The best E rated tire I've ever had. They aren't even in the same category as the old TowMax tires. I also had over 8K and they looked great.
I had G614s put on our Vengeance but if I was going with E tires, it would certainly be Westlakes. Forest River uses them a lot.
2015 F350 6.7L Lariat CC LB
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is offline   Reply With Quote
Old 03-04-2016, 01:43 PM   #24
10k on my Westlakes in the last year. I keep them at 80psi, VERY rarely run over 65mph - and then for only a short (minutes) time. Absolutely no problems, and they still look brand new.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
Old 03-04-2016, 01:46 PM   #25
Have several thousand on mine, they look and run great so far. Max psi and never run above 65 mph.
Wumba is offline   Reply With Quote
Old 03-04-2016, 01:54 PM   #26
I got about 1500 miles out of my set. always properly inflated but they still wore out fast. Good luck. Replaced with good year.
BRUCEANDCYNDI is offline   Reply With Quote
Old 03-04-2016, 02:12 PM   #27
Sc00ter's Avatar
Have westlake D load rated set. Only had them for a year but have had no issues and no reason to swap out with something else. Will probably upgrade to load range E like others have mentioned when the time comes. One thing I really liked about the GY Marathons I had on my last trailer, they had a thicker belt on the sides that would presumably help with accidental curb contacts. The WL treadwear is in line with my expectations for last season (2000-3000 miles).
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 03-04-2016, 05:23 PM   #28
beechjet16mf's Avatar
We have a Flagstaff 27RLWS with Westlake tires, and have about 18,000 mi. on them, including a trip up the ALCAN Highway. We haven't had any problems, but have TPMS on them, and I only have to add air or nitrogen about twice a year. They usually run at about 100 degrees F. and I have them at 55 PSI. They have used 1/3 of the tread, when compared to the original spare.
beechjet16mf is offline   Reply With Quote
Old 03-04-2016, 08:02 PM   #29
World Wide Wanderer
wahoonc's Avatar
Originally Posted by davidx2000 View Post
Slightly off topic, but what is the recommended tire rotation on a TT?
1 - Same side, rotate front to rear
2 - Flip left to right, and also front to rear
What about including the spare in the rotation if same/age/make/style as rolling tires?
I don't bother... life is short, go camping!
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 03-04-2016, 08:17 PM   #30
Steveinthehills's Avatar
Cool West Lake Tires
West Lake tires came as original equipment on the Solaire and this will be the fourth season on them. They look great and have about 1/2 of the tread wear left with about 12,000 miles on them. I had to replace the valve stems after the first year as they were all cracked. I keep them inflated to max pressure.
Steveinthehills is offline   Reply With Quote
tire, tires
