Old 10-29-2012, 12:39 PM   #1
psgrandpa1's Avatar
Artic pak and heat strips
After being out the last 3 nights with below 30 temp. I ran artic pak and heat strips ... I thought I was using electric... But after checking propane status... I am guessing they run off propane
Can someone confirm this
I am not ready to go home!!!
Bryan & Vonnie MATHIESEN
Hollister MO
Retired 2011
2017 SUNSEEKER MBS 2400W
2013 HONDA FIT SPORT
psgrandpa1 is offline   Reply With Quote
Old 10-29-2012, 01:24 PM   #2
Berkshire 390QS
NO3putt's Avatar
pretty sure
pretty sure they run on 12v. Not propane.
Skip
Old 10-29-2012, 02:19 PM   #3
TURBS's Avatar
12v electric.
Old 10-29-2012, 02:30 PM   #4
Witch Doctor's Avatar
Originally Posted by f1100turbo View Post
12v electric.
mine are electric to as tubo said, your heater FAU will suck some propane down fast when running if on.
Old 10-31-2012, 01:36 PM   #5
Anacortesians
They're 12Vdc and draw 7 amps each. My GT Class A has four of them. They can sure run your batteries down in a hurry if you don't have shore power hooked up.
I thnk they're hazardous to the tanks if they get turned on when the tanks are empty. The pads aren't very big, and putting 84 watts into a small area of an empty plastic tank could cause a problem. Also, the built-in t/stat (not adjustable) keeps them on until the sewage has been heated to 60 degrees, according to the manufacturer's spec sheet.
Frank and Eileen
No longer RVers or FR owners
